Page 13 of 28
FirstFirst ... 3 11 12 13 14 15 23 ... LastLast
Results 361 to 390 of 831
    Nov 2025
    London
    Originally Posted by iamghost View Post
    Originally Posted by r0gu3ptm View Post
    Thank you, done that, now i have this error, which I am not sure how to resolve:
    ─────────────────────────────── Service: NF ────────────────────────────────
    you cant use NF with andriod l3 cdm, only chrome l3 cdm which is not free
    Thank you, now is more clear.
  2. Originally Posted by tvdownloaderfan View Post
    I don't have any cookie folder ? But is this right ?
    # Override default directories used across unshackle
    directories:
    C:\unshackle\unshackle-main\unshackle\services
    cache: Cache
    C:\unshackle\unshackle-main\unshackle\cache\update_check.json
    cookies: Cookies
    no, this one...
    need add folder like that
    open 1st unshackle folder, add all folders apart services folder. add services folder under 2nd unshackle folder
    [Attachment 89474 - Click to enlarge]
    [Attachment 89475 - Click to enlarge]
    your unshackle.yaml like...
    directories:
      services: ./unshackle/services
      cache: ./Cache
      cookies: ./Cookies
      downloads: ./Downloads
      logs: ./Logs
      temp: ./Temp
      wvds: ./WVDs
      prds: ./PRDs
    This is ALL I put in unshackle.yaml ??
    Can someone please respond about this. I am totally lost
    Dec 2021
    england
    look at my unshackle.yaml
    tag:
    set_terminal_bg: false
    muxing:
      set_title: false
    credentials:
      ALL4: email:password
      ROKU: email:password
      CTV: email:password
    directories:
      cache: ./Cache
      cookies: ./Cookies
      dcsl: DCSL # Device Certificate Status List
      logs: ./Logs
      temp: ./Temp
      wvds: ./WVDs
      prds: ./PRDs
    Dependencies:
      Shaka-Packager: ./Shaka-Packager.exe
    cdm:
      default: asus_nexus_player_v5.0.0-android_db1d0620_4464_l3
      ALL4: genius_fashion_gae_tv_smart_tv_sl3000
    remote_cdm:
    - name: chrome
      device_name: chrome
      device_type: CHROME
      system_id: 27175
      security_level: 3
      host: https://domain.com/api
      secret: secret_key
    key_vaults:
    - type: SQLite
      path: key_store.db
    downloader: aria2c
    aria2c:
      max_concurrent_downloads: 4
      max_connection_per_server: 3
      split: 5
      file_allocation: falloc # none | prealloc | falloc | trunc
    # N_m3u8DL-RE downloader configuration
    n_m3u8dl_re:
      thread_count: 16
      ad_keyword: advertisement
      use_proxy: false
    # curl_impersonate downloader configuration
    curl_impersonate:
      browser: chrome120
    # Pre-define default options and switches of the dl command
    dl:
      best: true
      sub_format: srt
      workers: 16
      lang:
      - en
    EXAMPLE:
        bitrate: CBR
    headers:
      Accept-Language: en-US,en;q=0.8
      User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36
        (KHTML, like Gecko) Chrome/77.0.3865.75 Safari/537.36
  4. Can anyone tell me how to fix this with iplayer?
    uv run unshackle dl ip https://www.bbc.co.uk/iplayer/episode/m002dfzs/scams-scandals-holiday-parks-exposed
    OSError: /home/pc/Downloads/devine/temp/Subtitle_6ce398_stripped.vtt is not
    valid subtitle file: .vtt
    I found an old post saying ccextractor is not in path but it is mine
    $ ccextractor
    CCExtractor 0.93, Carlos Fernandez Sanz, Volker Quetschke.
    Teletext portions taken from Petr Kutalek's telxcc
    Everything even gets dloaded, its just some tiny error when muxing
    Edit, never mind, looking at iamghosts yaml above and copying this fixes it
    dl:
      sub_format: srt
  5. Hmm, now a different issue, definitely cant get this one to download, any ideas guys?
    uv run unshackle dl ip https://www.bbc.co.uk/iplayer/episode/m002lbvh/behind-bars-sex-bribes-and-murder-series-1-episode-1
    v 1.4.8 - © 2025 - github.com/unshackle-dl/unshackle
    Service Config loaded
    Loaded 0/0 Vaults
    Loaded Widevine CDM: 28919 (L3)
    ─────────────────────────────── Service: iP ────────────────────────────────
    Service is not Geoblocked in your region
    ──────────── Series: Behind Bars: Sex, Bribes and Murder (2025) ────────────
    1 seasons, S1(1)
    ───────────── Behind Bars: Sex, Bribes and Murder 2025 S01E01 ──────────────
    No versions in playlist API, falling back to webpage scrape.
    ╭───────────────────── Traceback (most recent call last) ──────────────────────╮
    │ /home/pc/Downloads/pyenvs/main/bin/unshackle:10 in <module> │
    │ 7 │ │ sys.argv[0] = sys.argv[0][:-11] │
    │ 8 │ elif sys.argv[0].endswith(".exe"): │
    │ 9 │ │ sys.argv[0] = sys.argv[0][:-4] │
    │ ❱ 10 │ sys.exit(main()) │
    │ 11 │
    │ /home/pc/Downloads/pyenvs/main/lib/python3.11/site-packages/click/core.py:14 │
    │ 42 in __call__ │
    │ /home/pc/Downloads/pyenvs/main/lib/python3.11/site-packages/click/core.py:13 │
    │ 63 in main │
    │ /home/pc/Downloads/pyenvs/main/lib/python3.11/site-packages/click/core.py:18 │
    │ 30 in invoke │
    │ 30 in invoke │
    │ /home/pc/Downloads/pyenvs/main/lib/python3.11/site-packages/click/core.py:17 │
    │ 99 in _process_result │
    │ /home/pc/Downloads/pyenvs/main/lib/python3.11/site-packages/click/core.py:79 │
    │ 4 in invoke │
    │ /home/pc/Downloads/pyenvs/main/unshackle/unshackle/commands/dl.py:624 in │
    │ result │
    │ 621 │ │ │ │ title.tracks.subtitles = [] │
    │ 622 │ │ │ │
    │ 623 │ │ │ with console.status("Getting tracks...", spinner="dots"): │
    │ ❱ 624 │ │ │ │ title.tracks.add(service.get_tracks(title), warn_only │
    │ 625 │ │ │ │ title.tracks.chapters = service.get_chapters(title) │
    │ 626 │ │ │ │
    │ 627 │ │ │ # strip SDH subs to non-SDH if no equivalent same-lang no │
    │ /home/pc/Downloads/pyenvs/main/unshackle/unshackle/services/iP/__init__.py:1 │
    │ 60 in get_tracks │
    │ 157 │ │ return Series(episodes) │
    │ 158 │ │
    │ 159 │ def get_tracks(self, title: Union[Movie, Episode]) -> Tracks: │
    │ ❱ 160 │ │ versions = self._get_available_versions(title.id) │
    │ 161 │ │ if not versions: │
    │ 162 │ │ │ raise NoStreamsAvailableError("No available versions for t │
    │ 163 │
    │ /home/pc/Downloads/pyenvs/main/unshackle/unshackle/services/iP/__init__.py:2 │
    │ 02 in _get_available_versions │
    │ 199 │ │ │ # Filter out audio-described versions │
    │ 200 │ │ │ return [ │
    │ 201 │ │ │ │ {"pid": v.get("id")} │
    │ ❱ 202 │ │ │ │ for v in redux_data.get("versions", {}).values() │
    │ 203 │ │ │ │ if v.get("kind") != "audio-described" and v.get("id") │
    │ 204 │ │ │ ] │
    │ 205 │
    AttributeError: 'list' object has no attribute 'values'
    Dec 2021
    england
    I got same as you, devine and unshackle getting error but VT work fine
    [Attachment 89564 - Click to enlarge]
  7. [QUOTE=iamghost;2785757]I got same as you, devine and unshackle getting error but VT work fine
    [/QUOTE
    Yeah I also tried yt-dlp, ukfta and freevine and all fail, weird. I use VT thanks
  8. <deleted>
    Feb 2022
    Search the forum first!
    [/QUOTE
    And the now ancient UK-FTA gets it too!
    [Edit ]I've also pushed an iplayer fix to TwinVine and envied.[/edit]
    Noob Starter Pack. Just download any Widevine media! Over 25,000 downloads for V6!.
  10. I changed this line in the IP service code to get it to work in unshackle sure Stabby will fix it properly
    # for v in redux_data.get("versions", {}).values()
    removed the values in line 189
    [Attachment 89586 - Click to enlarge]
    Works for me
  11. Originally Posted by A_n_g_e_l_a View Post
    Works for me
    Nice one peeps
  12. Originally Posted by iamghost View Post
    tag:
    muxing:
      set_title: false
    credentials:
      CTV: email:password
    directories:
      cache: ./Cache
      cookies: ./Cookies
      logs: ./Logs
      temp: ./Temp
      wvds: ./WVDs
      prds: ./PRDs
    Dependencies:
    cdm:
    remote_cdm:
    - name: chrome
      device_name: chrome
      device_type: CHROME
      system_id: 27175
      security_level: 3
      secret: secret_key
    key_vaults:
    - type: SQLite
      path: key_store.db
    downloader: aria2c
    aria2c:
      split: 5
    n_m3u8dl_re:
      thread_count: 16
      use_proxy: false
    curl_impersonate:
      browser: chrome120
    dl:
      best: true
      sub_format: srt
      workers: 16
      lang:
      - en
    EXAMPLE:
        bitrate: CBR
    headers:
    Look at it as in use all this in my unshackle.yaml ?
  13. @tvdownloaderfan what's your issue ?
  14. Originally Posted by PSXman_uk View Post
    If I use the unshackle.yaml given ? The lack of help on here ?
  15. directories:
    cache: ./Cache
    cookies: ./Cookies
    logs: ./Logs
    temp: ./Temp
    wvds: ./WVDs
    prds: ./PRDs
    Dependencies:
    you don't need any of this if you have git cloned unshackle put all your binaries in a folder for example bin in the root of c and path it in windows if that's what your using.
    after you have done the uv sync you should do uv run unshackle env check
    [Attachment 89614 - Click to enlarge]
    This will show if you have all the binaries you need
    Check your folder show up correctly
    uv run unshackle env info
    [Attachment 89615 - Click to enlarge]
    put your wvds and prds in the folders if you need any of these pm me
    for a test example of a encrypted download you could try
    uv run unsahckle dl --skip-dl -w S01E01 MY5 https://www.channel5.com/show/murder-before-evensong
  16. Tubi seems to be getting more sensitive to Windscribe VPN and me subscribing to ESET Windscribe Home Security Ultimate for another year because it has the Windscribe VPN. I would appreciate any advice; I am hoping I won't have to subscribe to another VPN because I tend to like to get the VPN from Best Buy Canada that way I don't have to use my credit card with more vendors then necessary.
  17. Originally Posted by PSXman_uk View Post
    directories:
    cache: ./Cache
    cookies: ./Cookies
    logs: ./Logs
    temp: ./Temp
    wvds: ./WVDs
    prds: ./PRDs
    Dependencies:
    This is giving a 500 internal error with me
    Download Failed...
    500 Server Error: Internal Server Error for url:
  18. 2nd Army Bridgeburners. WhiskeyJack's Avatar
    Aug 2024
    Torshavn
    directories:
    cache: ./Cache
    cookies: ./Cookies
    logs: ./Logs
    temp: ./Temp
    wvds: ./WVDs
    prds: ./PRDs
    Dependencies:
    Download Failed...
    Nothing you can do, that's an error on their side. Either wait some time and try again.
    https://linuxize.com/post/500-internal-server-error/
    that said,
    unshackle dl --skip-dl -w S01E01 MY5 https://www.channel5.com/show/murder-before-evensong
    Loaded 1/1 Vaults
    Loaded Widevine CDM: 8162 (L3)
    ─────────────────────────────── Service: MY5 ───────────────────────────────
    Service has no Geofence
    Authenticated with Service
    ────────────────────── Series: Murder Before Evensong ──────────────────────
    1 seasons, S1(6)
    ────────────────────── Murder Before Evensong S01E01 ───────────────────────
    Cached 2 Keys to 1/1 Vaults
    1 Video
    └── [H.264, SDR] | en | 1920x1080 @ 6000 kb/s, 25.000 FPS
    ⠧ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • --:-- • SKIPPED
    1 Audio
    └── [AAC] | en | 2.0 | 96 kb/s
    1 Subtitle
    └── [VTT] | en
    Widevine(AAAAMnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAA BISEKUGVvay90tll...)
    ├── a50656f6b2f74b65954a29cf1889ab0b:c811b54e989952d4c dd34d18d3e8b514*
    └── 7f76158eded9bd222e87a200cd51fe6a:c811b54e989952d4c dd34d18d3e8b514
    Skipped downloads as --skip-dl was used...
    Processed all titles in 0m4s
  19. Originally Posted by WhiskeyJack View Post
    directories:
    cache: ./Cache
    cookies: ./Cookies
    logs: ./Logs
    temp: ./Temp
    wvds: ./WVDs
    prds: ./PRDs
    Dependencies:
    Download Failed...
    that said,
    Loaded 1/1 Vaults
    1 seasons, S1(6)
    1 Video
    1 Audio
    1 Subtitle
    └── [VTT] | en
    Not working with me
    v 2.0.0 - © 2025 - github.com/unshackle-dl/unshackle
    Loaded 1/1 Vaults
    Loaded Widevine CDM: 8159 (L3)
    1 seasons, S1(6)
    1 Video
    ⠼ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • --:-- • SKIPPED
    1 Audio
    1 Subtitle
    └── [VTT] | en
    └── c77e314caa89246367c2111fb999aa11:c811b54e989952d4c dd34d18d3e8b514
    Processed all titles in 0m0s
    Dec 2021
    england
    not working for you?
    --skip-dl is skip download, try remove it
    uv run unshackle dl -w S01E01 MY5 https://www.channel5.com/show/murder-before-evensong
    1 Video
              ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • 00:34 • Downloaded
         1 Audio
              ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • 00:02 • Downloaded
         1 Subtitle
         └── [VTT] | en
              ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • 00:00 • Downloaded
         Widevine(AAAAMnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABISEKUGVvay90tllUopz
         xiJqws=)
         ├── a50656f6b2f74b65954a29cf1889ab0b:c811b54e989952d4cdd34d18d3e8b514*
         └── 4f8bb7a56efd65e0d864f2fb1567b512:c811b54e989952d4cdd34d18d3e8b514*
         Track downloads finished in 0m34s
         Multiplexing...  ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • 00:03
         �� Title downloaded in 0m39s!
  21. Originally Posted by iamghost View Post
    1 Video
         1 Audio
         1 Subtitle
         └── [VTT] | en
         xiJqws=)
    1 Video
    ⠴ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • --:-- • LICENSED
    1 Audio
    ⠴ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • --:-- • FAILED
    1 Subtitle
    └── [VTT] | en
    └── a50656f6b2f74b65954a29cf1889ab0b:c811b54e989952d4c dd34d18d3e8b514*
    from Local SQLite
    ❌ Download Failed...
    'charmap' codec can't decode byte 0x81 in position 123: character
    maps to <undefined>
    An unexpected error occurred in one of the download workers.
    See the error trace above for more information.
  22. Member
    Dec 2021
    england
    it not the fault of unshackle. it work everyone machine but your PC/laptop not, maybe not in english
  23. So apparently there is a bug as you can't download more than one episode at a time. Can you fix this Stabbedbybrick ?
  24. Originally Posted by tvdownloaderfan View Post
    -w, --wanted EP_RANGE Wanted episodes, e.g. `S01-S05,S07`, `S01E01-S02E03`, `S02-S02E03`, e.t.c, defaults to all.
  25. Originally Posted by PunchDrunkL0ve View Post
    ?? This for example only downloads first episode
    uv run unshackle dl STV https://player.stv.tv/summary/disney-moonlighting/
  26. Member
    Dec 2021
    england
    problems is just you and your PC...
    working fine with me and everyone machine
    [Attachment 89627 - Click to enlarge]
    download episode 1...2....
    [Attachment 89628 - Click to enlarge]
  27. possible issue with shaka-packager in the binaries dir change shaka-pacger.exe to the one with _ or change decryption to mp4decrypt
  28. Folks in season 2 episode 14 it just grinds to a halt for some reason, no error just hangs ? Anyone else ? Up until here all is good
    [Attachment 89639 - Click to enlarge]
  29. Originally Posted by tvdownloaderfan View Post
    I don't know the answer but be encourage you are close to getting it working with the advice you have been given. You also have fast internet so that will be handy when downloading whole seasons and or series.
  30. Member
    Dec 2021
    england
    it not just you, we have same thing.
    dont ask me where i get it
    here s02e14 1080p.
    https://gofile.io/d/QAMxWe
