  1. Hello,
    I would like to start using PlayReadyProxy2 and I wanted to get this two files needed to create de .prd file.
    I remember following a guide to get the files needed to create de .wvd for WideVineProxy2, but I don't find anything to get this two for PlayReady.
    Some kind of clue you can tell me to keep investigating?
    Thank you.
    Dec 2021
    england
    pyplayready create-device -c bgroupcert.dat -k zgpriv.dat
  3. No instructions provided, AFAIK. Use existing prds, e.g. here.
  4. Originally Posted by ytdlhelp View Post
    works for you?
    playback doesn't works, and it's fine, but the extension didn't generate any key
