Hello,
I've some bad deinterlaced clips with some probems on lines.
You can see it on the glasses in the testfile clip.
In Hybrid with the SangNom filter I get some improvement in some frames but not on the hole clip.
Also trying the other filters in the "AntiAliasing" tab, but give no good results for me.
Can someone help me out?
Of course I don't have the original Interlaced footage available.
Playing around with this, I (fixed a bug in Hybrid related to gimmick resizing&masking) and tried this:
(requires latest dev and torch add-on)
General idea:- create a filtered version of the clip, where you:
- downscale
- filter on the region of interest with BasicVSR++
- re-upscale
- combine filtered and original (masked)
- try remove/lessen the flickering with SMDegrain(dct=1)
a. the masking on combining is tricky, so that ideally only the stuff that we want to change gets changed
b. it's slow and requires the torch add-on
Maybe someone else has a better idea to handle this. (maybe down-scalling and applying some aa or vinverse might work, or maybe a nifty use of SMDegrain)
Here's the script and a single image preview. Attached the result.
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini - create a filtered version of the clip, where you:
Non-Removeable Jaggies
By Alwyn in forum Video ConversionReplies: 10Last Post: 4th Oct 2024, 04:22 -
Removing Interlace Jaggies from a Progressive Video
By Alwyn in forum RestorationReplies: 7Last Post: 17th Sep 2023, 00:28 -
Quick Dot Crawl /Antialiasing Avisynth Question
By Vaengence in forum Video ConversionReplies: 6Last Post: 15th Dec 2021, 22:26 -
How to add Aliasing/Jaggies to my footage
By sOgUn in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 21st Apr 2021, 19:50 -
By sOgUn in forum Newbie / General discussionsReplies: 0Last Post: 20th Apr 2021, 19:21
