Hi all,
I'm trying to extrat or convert some videos from a course that uses a custom video player with HWID lock. The video files have the .vpy extension. Thanks to a friend I can now play them using an unlocked version of the player, but it’s terrible.
I’d like to convert the videos to a standard format like MP4 for personal use only (I’m not redistributing anything).
Here’s what I found:
Code:The player runs via: Player_Unlock.exe "video.vpy" It loads libwzplayer2.dll and EDOG.dll during playback I monitored it with Process Monitor but didn’t find any obvious temp files yet
I’m looking for tips on:
Any tips on how to analyze or extract these files would be highly appreciated.Code:Identifying the real video format inside .vpy files Extracting or converting these videos Tools or methods to analyze or dump the video stream
Thanks!
`.vpy` files are typically associated with VirtualDub, a video capture and processing utility for Windows. These files are script files that contain instructions for VirtualDub on how to process video files. The actual video data is not stored within the `.vpy` file itself; instead, it references the video file that VirtualDub should process.
### Identifying the Real Video Format Inside .vpy Files
To identify the real video format, you need to look at the contents of the `.vpy` file. This file is usually a plain text file that contains scripting commands. Here’s a basic example of what a `.vpy` file might look like:
```plaintext
# VirtualDub script file
# Load the video file
input = "input_video.avi"
# Apply filters (if any)
# filter = "filter_name"
# Output settings
output = "output_video.avi"
In this example, the `input` variable specifies the actual video file that VirtualDub will process. The real video format will be the format of the file specified in the `input` variable.
### Extracting or Converting These Videos
To extract or convert the videos referenced in a `.vpy` file, you can use VirtualDub itself. Here are the steps:
1. **Open VirtualDub**: Launch the VirtualDub application.
2. **Load the Script**: Go to `File` > `Open video file...` and select the `.vpy` file.
3. **Process the Video**: Follow the instructions in the script to process the video. You can save the processed video by going to `File` > `Save as AVI...` or `File` > `Save as...` and choosing the desired output format.
### Tools or Methods to Analyze or Dump the Video Stream
If you need to analyze or dump the video stream, you can use several tools:
1. **FFmpeg**: A powerful multimedia framework that can decode, encode, transcode, mux, demux, stream, filter, and play almost anything that humans and machines have created. You can use FFmpeg to analyze and dump the video stream.
```sh
ffmpeg -i input_video.avi
This command will provide detailed information about the video stream.
2. **MediaInfo**: A convenient unified display of the most relevant technical and tag data for video and audio files.
```sh
mediainfo input_video.avi
This command will give you a detailed report of the video file's properties.
3. **VirtualDubMod**: An enhanced version of VirtualDub with additional features and filters. You can use it to analyze and process video files.
### Tips on How to Analyze or Extract These Files
1. **Read the Script**: Open the `.vpy` file in a text editor and read the script to understand what operations are being performed on the video.
2. **Use VirtualDub**: Load the `.vpy` file in VirtualDub to see the video and apply any necessary filters or conversions.
3. **Use FFmpeg**: For more advanced analysis and conversion, use FFmpeg commands to extract and convert the video stream.
4. **Check Metadata**: Use tools like MediaInfo to check the metadata of the video file to understand its format and properties.
By following these steps and using the mentioned tools, you should be able to identify, analyze, and extract videos referenced in `.vpy` files effectively.There is nothing wrong .. with my environment -
I know that vpy is used for Vapoursynth/Python scripts, first time I read that it's used for VirtualDub script files,... + I doubt that any player would use VirtualDub,...
users currently on my ignore list: deadrats, Stears555, marcorocchini -
@pitico
can you upload the video.vpy file ..There is nothing wrong .. with my environment
Need Help Extracting Keys from Service with Custom Payload
By josephsamual in forum Video Streaming DownloadingReplies: 9Last Post: 27th May 2024, 11:52 -
Recorded videos in pot player are silent for the first second
By Triranma in forum Software PlayingReplies: 0Last Post: 18th Apr 2024, 16:53 -
download stv player videos without login
By barry25 in forum Video Streaming DownloadingReplies: 4Last Post: 11th Jun 2023, 05:27 -
need to download videos from stv player site
By barry25 in forum Video Streaming DownloadingReplies: 1Last Post: 10th Jun 2023, 05:31 -
Download videos from STV Player
By onchunandrew in forum Video Streaming DownloadingReplies: 2Last Post: 25th Jun 2021, 10:08
