  1. I am trying to restore a DVD that has terrible blending, but I can't figure out the correct approach. The video seem to have too many blended frames. I tried separating the fields and it looks like some fields are clean while others have a large amount of blends, and it alternates between top field and bottom field, but not in an exact pattern...
    I'm trying to share a clip but all I could do was cut part of the vob as an avi clip with virtualdub, I don't think that's enough?
    https://drive.google.com/file/d/1r2B4NnV56uKr3vRJRV2FsagTFAOkMixw/view?usp=sharing
    Mar 2008
    Open the vob with Avidemux. Set the cut in points (A and B buttons), set the "output format" (lower left) to mpeg-ps
    Save as an mpg file and post here.
  3. Blending is already in the fields,...
    you can blur and throw stuff at it, but I doubt there is much to salvage,...
    Maybe ExBlend can help a bit, but I doubt it,..
    Cu Selur
  4. Thank you for trying Selur, I was indeed afraid that it would be unsalvageable... but I had a sliver of hope when I saw that the blending wasn't as strong on certain fields. I tried selecting the best looking field for each pair but I can't figure out a decent repeatable ratio. Any idea to do something like that automatically? A function that would be able to detect for two frames which has the less blending?
  5. Sadly, since the blending is nearly in every frame I have not much hope for that and don't know anything that is reliably for such a source.
