lt operate?
My samsung has secretly a NTSC-M tuner and can operate on 110 volt, is this normal?
HTML Code:
https://www.manualslib.com/manual/699799/Samsung-Ue22d5000.html?page=12#manual
Wouldn't surprise me, it simplifies the manufacturing and shipping. A lot of products are built like that. Features are limited through software.
DV cams with passthrough shipped to UK had that feature removed because it was taxed as VCR. If I recall correctly you could flash bios to enable it. -
thecoalman is right, nowadays (from many years) family of devices share same HW and usually software - there are features activated by manufacturer to differentiate portfolio (frequently those options can be activated in service menu)
agree with pandy, that's the correct answer. anything that will make them save money! also saw it on some sonys
I’ve actually heard of that happening on certain Samsung models. They sometimes include extra tuner compatibility or dual voltage support depending on the region they were manufactured for. It’s not really “secret,” more like they standardize parts across markets. If you’re unsure, I’d recommend double-checking with samsung electronics customer service. They can confirm if your exact UE22D5000 unit is meant to handle NTSC-M and 110V safely.
secret client iD from app sunnxt.com using frida
By Yamiraan in forum Video Streaming DownloadingReplies: 1Last Post: 20th Sep 2024, 16:23 -
Canopus ADVC 110 SECAM (B&W)
By TONYFRANCE in forum Capturing and VCRReplies: 15Last Post: 6th May 2023, 21:43 -
TV TUNER CARD "ViXS PureTV-U 480B0 (NTSC/ATSC)" HP Desktops ?
By sonomablue in forum Capturing and VCRReplies: 3Last Post: 8th Apr 2022, 17:56 -
CED, PAL on NTSC player, speeds seems too normal?
By anonymoustly in forum MediaReplies: 24Last Post: 12th Mar 2022, 14:01 -
Canopus ADVC 110 Whistle
By Gary Heejama in forum Newbie / General discussionsReplies: 0Last Post: 4th Apr 2021, 23:45
