    Aug 2021
    Australia
    I tried with yt-dlp but it is just keep on showing 'the channel is not currently live' even with all the cookies, cookies from browser or --geo-bypass-country command
    Can anyone help
    Just any live is fine as long as I get to know how to do it but the live I tried was https://www.tiktok.com/@leagueoflegends/live because it was just live
  2. Code:
    https://pull-f5-tt01.tiktokcdn.com/game/stream-3576340410910639036_sd.flv?_session_id=139-20250709115827A7FCAEFBE5E4A50E5732.1752033513734&_webnoredir=1&abr_pts=-2800&expire=1753243108&sign=43a41cdb63287b95dd4c86db7ffb45a0
    Aug 2021
    Australia
    Where can I get that from? + can I change to highest quality?
  4. Originally Posted by yy0901 View Post
    Browser developer tools, network tab, search for ".flv" pattern
    Aug 2021
    Australia
    ohh gotcha!! thank you!!!
    Just one more Qs, when I want to stop the extracting I did ctrl+c and it leave the file as .flv.part
    do you know if there's any way that I can make either .ts or .mkv? or extract in diff vid format?
    I tried ffmpeg but it is giving me error (unknown codec) and when opening changed file does not play :/
  6. Originally Posted by yy0901 View Post
    Have you tried to remove the ".part" and rename the file as ".flv"? VLC should open it if the video is not corrupted and does not have DRM.
    To convert it to mkv you can use mkvtoolnix, for example. It is a gui which makes the process very easy.
