I'm trying to help a friend who just purchased an Avermedia 300 to basically function as DVR. He used to have the same setup that I use source input > ***splitter > Avermedia EzRecorder 130 > drive.
He purchased an Avermedia 300 but after the blue light stops flashing, it turns solid blue, but shortly after that, it becomes solid red, which according to the booklet that came with the device should mean an error, which could be protected content.
Any advice about the Avermedia 300? Does it function in the same way as the 130?
*** This device
https://www.amazon.com/ViewHD-Port-Powered-Splitter-1080P/dp/B004F9LVXC
The ER330 is signaling a problem with its connection to the TV. Connect the ER330 to any 1080p TV. Another solution is to feed the ER330 a 1080i input signal. The ER330 will then (or at least should) switch its output to 1080i.
Try disconnect splitter. -
Sorry for the slow reply to this. I was traveling for work and he needed to test again. The short version is that the ER330 works with one provider but not with another. I can't believe the flags are radically different. Is there another type of splitter besides the one I linked above that serves a similar function with HDMI connections?
Probably this one and anyone else who looks the same. It works for me.
https://pl.lanberg.eu/produkt/splitter-video-lanberg-hdmi-2x-hdmi-4k-port-micro-usb-czarny
[AVerMedia News] Avermedia RECentral HDCP Protect Remove!!!
By Cauptain in forum Capturing and VCRReplies: 222Last Post: 10th Dec 2025, 12:12 -
Avermedia C727 and Windows 10 update?
By NLP in forum ComputerReplies: 0Last Post: 6th May 2023, 22:19 -
Avermedia C027 and C727?
By NLP in forum Capturing and VCRReplies: 8Last Post: 11th Oct 2022, 19:01 -
AVERMEDIA CE310B or IO DATA GV-USB2, which one and why?
By Joćo Alexandre in forum Capturing and VCRReplies: 1Last Post: 23rd May 2022, 13:29 -
Avermedia capture card
By vid89 in forum Capturing and VCRReplies: 4Last Post: 4th Jan 2021, 05:37
