  1. Has anyone here had problems "fixing a time difference" or "overwriting a datecode" in DVDate??
    Fix a time difference of +1hr results in +10hrs.
    Overwrite Datecode results in second counting as milliseconds.
    Did you find a solution?
    Is there another software that can modify subcode in DV AVI files to fix time?
    May 2005
    PAL User
    I didn't try fixing a time difference but the "change datecode" works here, version 7.1.
    I had a file with a (starting) datecode of 18/03/2005 18:36:23 and manually input 18/03/2005 19:36:23 and DVDate changed it to 1936.
    Perhaps explain in detail the steps you're taking and we can check.
    May 2005
    PAL User
    I just checked my video editor (it can insert titles based on the timecode at any point in the file) and the tape timecode has definitely changed by the 1 hour change I put in.
    May 2005
    PAL User
    Chris, I see you negatively commented on the DVDate download page. As I said above, it worked for me. What steps did you take to see if it can be replicated?
    FYI, I see DVDate has just been updated to 8.3.7. What version were you using?
