A local shop is transferring an old family VHS tape to mp4 and upscaling it to 1080 in the process. They're giving it to me as an MP4, upscaled to 1080. What software would I need to turn that into a format that I could burn to a Blu-ray that would play in an ordinary Blu-ray player - not one that can play an MP4?
I have ImgBurn, but I understand that it can't do that kind of conversion to a standard Blu-ray disk structure itself.
Using dedicated Blu-ray authoring software that transcodes (BDMV) structures files correctly, and generates recommended menus or navigation.
If you've only got one tape, I'd ask the shop to do it; they should be able to author a bluray disk.
The shop should of asked right away if they wanted to make you an authorized blu-ray,making you a mp4 sounded kinda lazy.
BD Rebuilder can import .mp4 and author and burn a compliant Bluray, including basic menus.
How to Burn a Blu Ray M2Ts File Ripped By Makemkv
By zipsick in forum Authoring (Blu-ray)Replies: 1Last Post: 9th Apr 2025, 02:43 -
New to Blu Ray Burning. How do you burn a 42gb Blu Ray ISO on a 8.5 DL DVD
By zipsick in forum Authoring (VCD/SVCD)Replies: 4Last Post: 23rd Mar 2025, 10:50 -
Advice with encoding mp4 to compliant blu ray file with close to loseless
By Littlebase631 in forum Video ConversionReplies: 7Last Post: 2nd Jan 2024, 13:29 -
HDR video to standard Blu-ray
By frodawgg in forum Video ConversionReplies: 5Last Post: 16th Jul 2021, 12:26 -
Can AVCHD fit more content on a Blu-ray than standard encoding?
By Kal-El in forum Authoring (Blu-ray)Replies: 10Last Post: 26th Dec 2020, 08:04
