what is up with that ?
i click on the tools and goto download it and guess what ?
"unauthorized download" at doom9
what is a dead link doing at vcdhelp.com ?
i finally get a copy of this "supposedly" wonderful tool and guess what ?
i double click the .exe and it flashes up for a sec and then disappears
then i try with the GUI for it and i get the same result !
is there a trick to this proggie that i don't know about ?
someone please help
i have many divx that convert to s/vcd
now i burned a few and my pioneer dv-440 skips all the time because it can't handle the conversion to 29 fps on the fly
i am on winxppro
HELP !!
" I am the one which you do not want to see, becasue I am the one which makes you see yourself" H.R.
Just encode the divx to 29.97 even if the source is 23.976 to start with. I take it this is for a vcd right?
pulldown.exe is a command line tool - open a command window by using the "run" command from the start menu.
Run "cmd.exe" for Win2K or XP and "command.exe" for 98 and ME.
Just type "pulldown infilename outfilename"
to do the pulldown - couldn't be simpler. -
the original post stated that i tried the GUI
i will try to encode to 29fps that should do it
thanks for the help guys" I am the one which you do not want to see, becasue I am the one which makes you see yourself" H.R.
2:4 Pulldown
By supervehicle in forum Video ConversionReplies: 23Last Post: 3rd May 2011, 16:53 -
explorer.exe / drwtson32.exe keeps closing
By coolcoates in forum ComputerReplies: 7Last Post: 28th Nov 2007, 08:42 -
3:2 Pulldown and Interpolation
By PuzZLeR in forum Video ConversionReplies: 1Last Post: 28th Oct 2007, 11:49 -
3:2 pulldown?
By blizzery in forum Video ConversionReplies: 3Last Post: 24th Jul 2007, 06:38 -
Using pulldown
By MysticE in forum Video ConversionReplies: 2Last Post: 14th Jul 2007, 03:25
