  1. Hi. I recently used the PVR+ function of my new TV - *Vortex AV24EVA1VS (*powered by Vestel), recording a sports event.
    Got only some .bin files and some weird extensions. Screenshot --> https://i.ibb.co/Y7gQkh0Q/PVR.jpg
    Is there any chance to decrypt them?
    I'm familiar with FFMpeg, but not an expert and I didn't get too far. The PVR of my previous TV generated .tsv files, so I (wrongly) assumed this one would do the same.
    Or a free software maybe, if it exists? I don't know if I'll ever use it again, so I might just need this recording. On the original TV it plays perfectly, but nowhere else.
    This is the archive with all files --> https://www.swisstransfer.com/d/1117a1b9-8319-4c27-9f06-e29f22adc487
  2. if u were to google search the file extensions (suoyin xinxi jmzn), it will lead u to this link:
    https://www.avforums.com/threads/recorded-files-are-unnamed-how-do-you-know-which-is-which.2524434/
    with a post
    ls -l REC000096
    total 699840
    drwxr-xr-x 2 1000 1000 32768 Mar 22 06:30 e43bc90d6815
    -rw-r--r-- 1 1000 1000 716341248 Mar 22 07:00 REC000096
    -rw-r--r-- 1 1000 1000 0 Mar 22 06:30 REC000096.auth
    -rw-r--r-- 1 1000 1000 8512 Mar 22 06:30 REC000096.elem
    -rw-r--r-- 1 1000 1000 834 Mar 22 06:30 REC000096.jmzn
    -rw-r--r-- 1 1000 1000 116544 Mar 22 07:00 REC000096.suoyin
    -rw-r--r-- 1 1000 1000 1240 Mar 22 07:00 REC000096.xinxi
    -rw-r--r-- 1 1000 1000 396 Mar 22 07:00 REC000096.xml
    which meant that Hisense TVs are using the same technology for PVR
    I found this, not sure if it will work:
    https://github.com/openlgtv/epk2extract
    you can look at posts in the "Issues" tab too:
    https://github.com/openlgtv/epk2extract/issues/59
