Hello All,
I want to complete my picture/video project, but have stumbling blocks. I've created a project with a VGMN Menu, 7 Titlesets with a menu for each one, and a group of titles for each titleset. Everything looked ok and I was able to create an .iso file a few days ago. I had to make a few changes. When, I go to create the burn, preview, create .iso, the preview opens in VLC and can play with no issues. It then asks me if I want to create an .iso file and I click yes. After a minute or so, I get an error message: failed. mkisoft: Permission denied. Unable to open disc image file. I want to create the .iso file. I tried clearing the cache, and lowering the bitrate to 64 from 125; however, nothing is working. I've attached a screenshot of the settings/error messages received. Any idea how to fix this? I am not a programmer and just want to be done with this project. I've tried other software programs, but DVD styler actually lets me drag and drop files, so I like that. Thanks for any help in advance!
It was a word document, but I'll upload the pictures.
[Attachment 87643 - Click to enlarge]
[Attachment 87644 - Click to enlarge]
[Attachment 87645 - Click to enlarge] -
It might have something to do with your target of E:\ , some programs don't like writing to to certain drive types.
Also your "Burn" temp directory has the ~ filename format. Probably picked up from the system path or environment variables.
May or may not be an issue.
I'd try creating two folders on your desktop, one for "temp" and one for the ISO target and use those.
Code:INFO: Audio ch 0 format: ac3/2ch, 48khz drc, 'en' STAT: fixed 4 VOBUs Start preview Executing command: "C:\Program Files\VideoLAN\VLC\vlc.exe" --started-from-file dvd:///C:\Users\davex\AppData\Local\Temp\dvd-out Creating ISO image Executing command: mkisofs -V "DVD-test 5" -o "C:\Users\davex\Downloads\dvd.iso" -dvd-video "C:\Users\davex\AppData\Local\Temp\dvd-out" 0.57% done, estimate finish Sat Jun 28 09:52:19 2025 5.15% done, estimate finish Sat Jun 28 09:53:17 2025 10.29% done, estimate finish Sat Jun 28 09:53:27 2025 15.44% done, estimate finish Sat Jun 28 09:53:30 2025 20.01% done, estimate finish Sat Jun 28 09:53:33 2025 25.15% done, estimate finish Sat Jun 28 09:53:30 2025 30.30% done, estimate finish Sat Jun 28 09:53:34 2025 35.44% done, estimate finish Sat Jun 28 09:53:40 2025 40.02% done, estimate finish Sat Jun 28 09:53:43 2025 45.16% done, estimate finish Sat Jun 28 09:53:43 2025 50.31% done, estimate finish Sat Jun 28 09:53:46 2025 55.45% done, estimate finish Sat Jun 28 09:53:47 2025 60.03% done, estimate finish Sat Jun 28 09:53:45 2025 65.17% done, estimate finish Sat Jun 28 09:53:41 2025 70.32% done, estimate finish Sat Jun 28 09:53:38 2025 75.46% done, estimate finish Sat Jun 28 09:53:37 2025 80.03% done, estimate finish Sat Jun 28 09:53:36 2025 85.18% done, estimate finish Sat Jun 28 09:53:35 2025 90.32% done, estimate finish Sat Jun 28 09:53:34 2025 95.47% done, estimate finish Sat Jun 28 09:53:33 2025 Total translation table size: 0 Total rockridge attributes bytes: 0 Total directory bytes: 4248 Path table size(bytes): 42 874641 extents written (1708 MB) Cleaning temporary directory File 'C:\Users\davex\AppData\Local\Temp\dvd-out\VIDEO_TS\VIDEO_TS.IFO' couldn't be removed (error 32: The process cannot access the file because it is being used by another process.) Can't remove file 'C:\Users\davex\AppData\Local\Temp\dvd-out\VIDEO_TS\VIDEO_TS.IFO' Generating was successful.
How to download from zee5.com from Bangladesh(Access Denied)
By safwan in forum Newbie / General discussionsReplies: 9Last Post: 24th Nov 2024, 15:51 -
HTTP 403 Access Denied (Binge)
By CrymanChen in forum Video Streaming DownloadingReplies: 27Last Post: 8th Aug 2024, 15:49 -
403: (access denied) Error While Writing Zee5 Live Tv Using Ffmmeg
By StarkGang in forum Video Streaming DownloadingReplies: 1Last Post: 9th Jun 2021, 01:44 -
TMPGEnc Authoring works 4 - Access is Denied (Error code 0x80070005)
By The Roo in forum Newbie / General discussionsReplies: 3Last Post: 17th Mar 2021, 18:34 -
Virtualdub export image sequence "Access is denied"
By ecc in forum Video ConversionReplies: 5Last Post: 6th Jul 2020, 09:43
