hello
is there any free software that i can use to reduce a Blu ray of 30 gb to fit at disk of 25 ?
i have both folders BDMW and CERTIFICATE
i test with cloneDB and it work i was able to burn it but it insert a watermark
i read that ImgBurn can do it but i'm not sure how to do it
ImgBurn does not compress. So no for using ImgBurn to do this.
I would use BD Rebuilder. -
As "cholla" said. BD Rebuilder is an excellent free software. You can choose the output size/disc size, main movie only, all the extras/menu etc.
4K UHD Blu Ray Remux to Blu Ray (regular) for burning
By Damirko1981 in forum Authoring (Blu-ray)Replies: 9Last Post: 9th Apr 2025, 20:04 -
New to Blu Ray Burning. How do you burn a 42gb Blu Ray ISO on a 8.5 DL DVD
By zipsick in forum Authoring (VCD/SVCD)Replies: 4Last Post: 23rd Mar 2025, 10:50 -
ISO External Blu-Ray (or 4k blu-ray) burner drive for PC (Windows 11)
By derricomonico in forum Blu-ray RippingReplies: 3Last Post: 16th Sep 2024, 17:16 -
1 blu ray movie 80gb in 2 blu ray of 40gb
By killbill831 in forum Authoring (Blu-ray)Replies: 2Last Post: 18th Oct 2022, 23:44 -
Visio Blu Ray player vbr120 unable to read Blu ray discs
By juntjoo in forum DVD & Blu-ray PlayersReplies: 3Last Post: 14th Sep 2020, 13:02
