  1. I have a problem downloading video with 6CH audio.
    Command i use:
    N_m3u8DL-RE.exe https://r.cdn-ncplus.pl/vod/store01/CAP_21055311/_/hd4-hssdrm02.ism/Manifest -sv res=\"x1080\" -sa codec=\"*EC-3\":lang=\"pol\" --key 65347ed53e174054a74c76c549f901b6:5a44539232d3bdd748d42676f6c7f0c5 -M format=mp4
    but there's an error like this and file is without audio track:
    17:29:34.762 INFO : Decrypting using MP4DECRYPT...
    17:29:35.150 WARN : Manifest_2025-06-16_17-24-08.mp4
    17:29:35.150 WARN : Manifest_2025-06-16_17-24-08.pol.m4a
    17:29:35.151 WARN : Muxing to Manifest_2025-06-16_17-24-08.MUX.mp4
    17:29:35.258 WARN : [aac @ 000000000080f800] Audio object type 0 is not implemented. Update your FFmpeg version to the
    newest one from Git. If the problem still occurs, it means that your file has a feature which has not been implemented.
    17:29:35.260 WARN : [mov,mp4,m4a,3gp,3g2,mj2 @ 00000000008072c0] Failed to open codec in avformat_find_stream_info
    17:29:35.260 WARN : [aac @ 000000000080f800] Audio object type 0 is not implemented. Update your FFmpeg version to the
    17:29:35.262 WARN : [mov,mp4,m4a,3gp,3g2,mj2 @ 00000000008072c0] Could not find codec parameters for stream 0 (Audio:
    aac (ec-3 / 0x332D6365), 96000 Hz, 0 channels, fltp, 191 kb/s): unspecified number of channels
    17:29:35.263 WARN : Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options
    17:29:35.263 WARN : [mp4 @ 00000000029e1cc0] track 1: codec frame size is not set
    17:29:36.109 WARN : Cleaning files...
    17:29:36.181 WARN : Rename to Manifest_2025-06-16_17-24-08.mp4
    17:29:36.181 INFO : Done
    also tried manual download, decrypt and ffmpeg mux but it gives me:
    [aac @ 0000000002b52140] Audio object type 0 is not implemented. Update your FFmpeg version to the newest one from Git. If the problem still occurs, it means that your file has a feature which has not been implemented.
    [mov,mp4,m4a,3gp,3g2,mj2 @ 0000000002f43040] Failed to open codec in avformat_find_stream_info
    [mov,mp4,m4a,3gp,3g2,mj2 @ 0000000002f43040] Could not find codec parameters for stream 0 (Audio: aac (ec-3 / 0x332D6365), 96000 Hz, 0 channels, fltp, 192 kb/s): unspecified number of channels
    any idea how this can be fixed?
    Apr 2024
    Warszawa
    on the old manifest you won't download 5.1 audio because 5.1 audio has a different key than what you have
    old manifest (ism/Manifest) | new (.mpd)
    N_m3u8DL-RE "https://r.cdn-ncplus.pl/vod/store01/CAP_21055311/_/hd4-hssdrm02.ism/Manifest" --key 65347ed53e174054a74c76c549f901b6:5a44539232d3bdd74 8d42676f6c7f0c5
