Change the frame rate flag of the video from xy to xy*10.
Code:ffmpeg -itsscale <slowdownfactor> -i input.mkv -c copy output.mkv
users currently on my ignore list: deadrats, Stears555, marcorocchini -
Your likely to have problems playing a video 10 times faster than normal. For example, playing a 25 fps video at 250 fps probably won't work because the player can't decode 250 frames every second. Decimating or blending frames and re-encoding is safer in such a case.\
If you have a very low frame rate video simply increasing the playback speed will work. For example, playing a 3 fps video at 30 fps will probably be ok.Last edited by jagabo; 16th Jun 2025 at 13:07.
freeware that let's you change the speed of a video?
By DaneClark in forum EditingReplies: 1Last Post: 20th Aug 2022, 21:31 -
Mux 2 bluray with different fps: change audio or video speed (for quality)?
By precipizio in forum Blu-ray RippingReplies: 17Last Post: 23rd May 2022, 02:10 -
Change FPS playback speed of mp4 Video without converting it
By DReffects in forum Video ConversionReplies: 2Last Post: 19th Apr 2022, 14:33 -
Sync audio/video of Animation/Cartoon Bluray -> video speed VS audio speed
By precipizio in forum Blu-ray RippingReplies: 4Last Post: 14th Dec 2021, 10:07 -
Change OGG playback speed
By Randombit in forum AudioReplies: 6Last Post: 22nd Aug 2020, 03:22
