  1. I don't know why but videos join correctly in Avidemux. While in VirtualDub2 I get error after file->save video
    VirtualDub Error
    Direct stream copy cannot be used with this video stream.
    You may want to select different Input Driver.
    OK
    And after File->Export->stream copy only first appended file is saved...
  2. In VirtualDub2 I get error after file->save video and after File->Export->stream copy only first appended file is saved too. Please, help me too!
  3. It's probably because one of the videos is being decoded with the ffmpeg input driver, which decodes the video to a raw format, and therefore direct stream copy can't be used.
    Maybe post the details of each video. You can get that info with MediaInfo.
