Have an LG WebOS 24 that refuses to play SOME AVI containers with XVID as codec, LG website says XVID is supported except 3 wrap-point GMC..
here is an example of a failing codec:
They play just fine on PC and other TVs with batter support, questions are:HTML Code:Video ID : 0 Format : MPEG-4 Visual Format profile : Advanced Simple@L5 Format settings : BVOP2 Format settings, BVOP : 2 Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default (MPEG) Muxing mode : Packed bitstream Codec ID : XVID Codec ID/Hint : XviD Duration : 23 min 56 s Bit rate : 1 793 kb/s Width : 640 pixels Height : 480 pixels Display aspect ratio : 4:3 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Bits/(Pixel*Frame) : 0.243 Stream size : 307 MiB (90%) Writing library : XviD 1.2.0.dev47 (2006-11-01)
1) Is there a tool/hack/header "editor" that would change the GMC to not be there at all? without having to re-encode 100's of files?
of course re-encoding is the "easy fix", but involves 100's of files and a lot of work..
2) looking on the LG/tv side if able to add codecs, that's secondary, main interest if the FILES can be somehow modified to allow playback directly..
Thanks for any tips.
Results 1 to 1 of 1
AVI XVID with GMC / QPEL not recognised by hardware players
By SmurfRecorder in forum Video ConversionReplies: 9Last Post: 16th Jun 2025, 17:35 -
Trying to identify a movie (Possibly Shaw VOD Exclusive)
By imkira3 in forum Off topicReplies: 8Last Post: 24th Feb 2025, 16:18 -
Oem crypto api, how to change it? Is it possibly?
By Xfinger in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Jan 2022, 17:15 -
how do I download these videos, from boxcast possibly?
By n00n00 in forum Video Streaming DownloadingReplies: 4Last Post: 12th Dec 2020, 10:25 -
errors due to constant updates with plugins
By Betelman in forum RestorationReplies: 6Last Post: 12th Sep 2020, 10:25
