Results 1 to 17 of 17
  1. Image
    [Attachment 87392 - Click to enlarge]
    i tried to get spoify audio with WidevineProxy2, but failed.
    it seems WidevineProxy2 cannot grab the license url in spotify chrome web.
    so tried with pywidevine with authorization and client-token in python headers, but also failed. it shows "401 Client Error"
    can i get some tips?
    thanks in advance.
  2. have sent you PM some hours ago ... read my PM
  3. Originally Posted by lomero View Post
    can you help me also?
  4. we have wonderful tool shared from **** for that, but at the moment, due to some spoty changes this tool not work
    wait news
  5. Originally Posted by lomero View Post
    wait news
    you have a github link for it?
  6. Originally Posted by lomero View Post
    wait news
    No Spotify-specific tools are needed if you want to get the audio file from the web version. Here is a screenshot of Chromium + audio request opened in DevTools + OpenWV output with the key for it (WidevineProxy2 works too). Just make sure you use a CDM from a physical device, because emulated ones are rejected.
  7. oh yes, you can find all data from network tab. and get the key
    just for some tracks it's possible do this. and easy to do
    no more convenient if your playlist is 100 tracks or more ... for that better use some tools
    however the tool mentioned above, is not available now. so the trick from network tab that's a good suggestion
  8. Originally Posted by ytdlhelp View Post
    wait news
    Edit:
    Got it. have a physical device, downloaded it and decrypted it!!!
  9. Originally Posted by lomero View Post
    really thank you
  10. Originally Posted by ytdlhelp View Post
    wait news
    thanks for your kind advice
  11. spotify api json to hls conversion
    for profile in profiles:
        print(profile["mime_type"], profile["max_bitrate"])
        segment_length = encoding["segment_length"]
        init = base_url + response_json["initialization_template"].replace("{{profile_id}}", str(profile["id"])).replace("{{file_type}}", profile["file_type"])
        start_time = int(encoding["start_time_millis"] / 1000)
        end_time = int(encoding["end_time_millis"] / 1000)
        type_name = "audio" if "audio" in profile["mime_type"] else "video"
        codec_name = profile.get("audio_codec") or profile.get("video_codec")
        name = f"{type_name}_{profile["max_bitrate"]}_{codec_name}.m3u8"
        with open(name, "w") as f:
            f.writelines(
                    '#EXTM3U\n',
                    '#EXT-X-VERSION:4\n',
                    '#EXT-X-MEDIA-SEQUENCE:0\n',
                    '#EXT-X-PLAYLIST-TYPE:VOD\n',
                    f'#EXT-X-MAP:URI="{init}"\n',
                    f'#EXT-X-TARGETDURATION:{int(round(segment_length)) + 1}\n'
            for time in range(start_time, end_time, segment_length):
                segment = base_url + response_json["segment_template"].replace("{{profile_id}}", str(profile["id"])).replace("{{file_type}}", profile["file_type"]).replace("{{segment_timestamp}}", str(int(time)))
                f.write(f'#EXTINF:{segment_length}\n')
                f.write(f'{segment}\n')
            f.write("#EXT-X-ENDLIST\n")
    with open("master.m3u8", "w") as f:
        f.writelines(
                '#EXTM3U\n',
                '#EXT-X-INDEPENDENT-SEGMENTS\n'
            name = f"{type_name}_{profile["max_bitrate"]}_{codec_name}"
            if type_name == "video":
                f.write(
                    '#EXT-X-STREAM-INF:'
                    f'BANDWIDTH={profile["video_bitrate"]},'
                    f'CODECS="{profile["video_codec"]}",'
                    f'RESOLUTION={f'{profile["video_width"]}x{profile["video_height"]}'},'
                    'AUDIO="default-audio-group"\n'
                f.write(f'{name}.m3u8\n')
            elif type_name == "audio":
                f.write(
                    '#EXT-X-MEDIA:'
                    'TYPE=AUDIO,'
                    f'URI="{name}.m3u8",'
                    'GROUP-ID="default-audio-group",'
                    f'NAME="{name}"\n'
    Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2
  12. Originally Posted by larley View Post
            f.writelines(
                    '#EXTM3U\n',
        f.writelines(
                '#EXTM3U\n',
                f.write(
                f.write(
                    '#EXT-X-MEDIA:'
                    'TYPE=AUDIO,'
                    f'NAME="{name}"\n'
    on windows browser (for me at chrome) it isnt needed download through hls converted from json.
    Look at F12 Network, there you will find files which come from https://audio-ak.spotifycdn.com/audio. That are the encrypted file as m4a. Download them and decrypt them with the key.
    The kid;key you can get with your tool WVProxy2, but it must be a .wvd from a physical device not an emulated.
    thats the easiest method.
  13. my code is for downloading videos, not single tracks
  14. Originally Posted by larley View Post
    ahh danke dir!!! habe nicht näher darauf geschaut.
  15. can you help me also?
  16. Originally Posted by Waltonpadilla View Post
    what exactly you need?
  17. Could you pretty please help me to download/decypher album from spotify? I did manage to get virtual device client_id and key - I will try it. I gues it wont work as other people mentioned.... But I will be able to get my hands on physical device l3 keys - I have some older phones which I would just have to root.
    But Im not really sure how to proceed - I cant see any playlist, nor do I see json file (which shouild then be somehow converted to hls playlist?).
    If possible, could somebody write me a PM?
    Thank you and best regards!
