When remuxing a DVD with MakeMKV some additional tags are inserted:
When using MKVToolNix on the file the tags are gone.Code:ID in the original source medium : 224 (0xE0) Original source medium : DVD-Video
How can i reinsert these tags?
And does anyone know what the name is because i can't find it in:
Extracting the tags before MKVToolNix using Mkvextract doesn't give me tags.Code:mkvpropedit.exe" "file.mkv" --list-property-names
Thanks!
I have not used ffmpeg for this but it has the capability to add "Metadata".
IDK if it can add these tags to a file.
I use this feature of ffmpeg to remove metadata & I may have played with adding some a while back.
Maybe some member with more expertise can post a ffmpeg code for you.
I do not but I hope someone here does as I would like to know myself.Last edited by cholla; 14th Jun 2025 at 10:50.
Maybe a read of this will help.
https://www.systutorials.com/docs/linux/man/1-mkvpropedit/
Specifically:-a, --add name=value
Adds a property name with the value value. The property will be added even if such a property exists already. Note that most properties are unique and cannot occur more than once.
Conversion of MKA files to .DTS and .WAV formats from original MKV source
By cybnmusic in forum MacReplies: 2Last Post: 25th May 2023, 17:07 -
How to change color in one source to the color from the other source?
By Platos in forum Newbie / General discussionsReplies: 42Last Post: 16th May 2023, 20:05 -
What MEDIUM do I use for giving out copies of a video in 2021?
By Gameshow Host in forum Newbie / General discussionsReplies: 3Last Post: 28th Sep 2021, 16:47 -
Medium preset vs custom setting
By marco000 in forum Video ConversionReplies: 1Last Post: 24th Jul 2021, 11:01 -
Can you increase bitrate higher than the original raw source video ?
By GoodEnough in forum Newbie / General discussionsReplies: 16Last Post: 1st Jan 2021, 07:38
