I cut several short clips from a video and want to join them together
I named the clips "Clip 1" "Clip 2" "Clip 3" etc, all in the correct order
But Avidemux doesn't combine them in the correct order. Often the first clip is last. Other times it seems random. I've tried naming the files in various different ways but I can't understand why it doesn't just process them in alphabetic order?
You can also use clever Ffmpeg-GUI.
Start the app, click join, drag all clips into the grid, order them as you like and click join.
Done.
MKVMerge: batch combine multiple MKV files together? (sorted by filename)
By rowjekto in forum Newbie / General discussionsReplies: 0Last Post: 17th Feb 2025, 14:17 -
Combine Videos with Multiple Audio Streams
By Jay123210599 in forum Newbie / General discussionsReplies: 1Last Post: 19th Nov 2023, 05:07 -
Combine MP4 and SRT together into MKV - multiple files
By Valnar in forum EditingReplies: 2Last Post: 30th May 2023, 18:31 -
Using Avisynth to play specific clips in sequence?
By Asterra in forum Newbie / General discussionsReplies: 1Last Post: 9th Dec 2022, 08:48 -
How to batch resize AND append multiple videos in Avidemux?
By savvyguy in forum Newbie / General discussionsReplies: 6Last Post: 28th Jul 2021, 18:00
