  1. I have recently created a bunch of ProRes master edits using various footage from both SD and HD movie sources.
    The mediainfo for the HD ProRes exports shows all Bt.709 information:
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    On the other hand, the mediainfo for the SD ProRes exports shows mixed Bt.709 & Bt.601 information:
    Color primaries : BT.601 NTSC
    Matrix coefficients : BT.601
    Does anyone know why this is? Shouldn't the SD version show solely Bt.601? Is there any problems with this result?
  2. It does not matter for transfer characteristic - because it's the same for bt601 and bt709.
    You can refer to Table E.4 in the ITU h265 document for a definitive reference
