  1. Member spidey's Avatar
    Apr 2001
    U.S.A.
    Not sure if this is the correct forum, but I believe it is.
    Here's another method I compiled from a few other posts as well. Thank you.
    ac3 to wav for s/x/VCD / avi with audio conversions of an DivX avi w/ ac3 audio streams as source
    I have had some problems with Audio Synch using the AVI2VCD Decompress tool while trying to
    convert an DivX with AC3 sound to SVCD. I dunno what the problem is with that.
    Here's a method that has worked well for me every time:
    Using Nandub, open the AC3 DivX. Then:
    Audio > Direct Stream Copy
    File > Save WAV....
    Rename the resulting file extension from xxx.wav to xxx.ac3
    Then using Ciler's AC3 tool (http://www.digitaldigest.com/dvd/downloads/ac3tool.html), you can convert the AC3 file to Wav or MP3. There's lots of options here, it's a nifty tool.
    The resulting audio file can then be used as the audio source, with your original avi being used as the video source in TMPG
    I hope this has been of some use...
    Get Nandub at http://doom9.org/Soft21/Encoders/MPEG4/nandub-binary-1.0rc2.rar on page http://doom9.org/software.htm
    ~~~Spidey~~~
    "Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
  2. Member spidey's Avatar
    Apr 2001
    U.S.A.
    Shoot, forgot above. In Nandub make sure to CONVERT your audio to 44100 x 16 x stereo - THEN save wav
    ~~~Spidey~~~
  3. Member spidey's Avatar
    Apr 2001
    U.S.A.
    LOL................No I was right the first post. Please disregard the 2nd
    ~~~Spidey~~~
