Hello,
I have a Japanese subtitle and an English one for the same movie but they have different timecodes.
Japanese has 729 lines, english 720. However they have some differences because the japanese one has some sound description, while the english one has initial cast credits.
I need to set the timecodes of the english one to match the japanese, I know how to export timecodes and import them in Subtitle Edit, but I'd need the same number of lines. What is the best approach for this work?
I have translated the japanese .srt to english so I can roughly compare the two files, but once I remove the credit lines from the english one, I should remove the sound lines from the japanese, and then I'd need to adjust those manually. Or is there any other tool I could use?
Try using SubSync (a Windows GUI tool) or ALASS.bat (a Windows command-line tool). ALASS is documented on its GitHub page, and SubSync is fairly self-explanatory.
Both are capable of taking a subtitle with off-timings and syncing it automatically to a reference subtitle with correct timings or to an audio track in a video file.
Both support multiple languages and subtitle inputs.
ALASS will handle multiple timing drifts in a subtitle (like for a TV show where the subs go out-of-sync at every commercial break) but SubSync only handles one uniform drift-and-shift.
ALASS will work automatically and SubSync will wait for you to output a subtitle (output the same format or your synced sub might lose some positioning/styling information). SubSync can also display the final drift-and-shift formula in the format drift × time + shift in case you want (for example) to enter them into MkvToolNixGUI manually instead of letting SubSync handle it. -
That is a very easy task using online tools. You have only to calculate the difference between two subtitles on miliseconds, and to adjust the english track.
You can use this web: https://subtitletools.com/subtitle-sync-shifter
Using the Merge lines function in Subtitle Edit gives overlap errors
By loninappleton in forum SubtitleReplies: 4Last Post: 13th Apr 2022, 17:59 -
ffmpeg to merge subtitle (no encoding)
By sambat in forum SubtitleReplies: 4Last Post: 16th Feb 2022, 06:12 -
how to merge multiple subtitle files in python?
By D.LUFFY in forum ProgrammingReplies: 2Last Post: 7th Nov 2021, 09:24 -
(subtitle edit) About "merge lines with same timecode"
By heisiheisi in forum SubtitleReplies: 5Last Post: 12th Oct 2020, 16:48 -
2 Blu Ray Discs, 1 srt subtitle file, do I have to rip and merge both discs
By sethhuner in forum Blu-ray RippingReplies: 5Last Post: 27th Jun 2020, 11:24
