    Oct 2015
    Dublin
    Hello!
    Can we create folders on tablets?
    How can I do that?
    Thanks for your help.
    May 2005
    PAL User
    Assuming Android, install the CX File Explorer app. That has the ability to create folders.
    Plugging in to your PC will also give access so you can create folders using Windows Explorer.
  3. Member Cornucopia's Avatar
    That's what I use also. Great little app.
