Hi,
I have downloaded MPV.Net (the last release 7.1.1.0) portable version, and I have added the folder "portable_config" with inside the folder "scripts".
The program use the portable folder.
If I add a command in input.conf it work fine.
The problem is LUA.
In the folder "portable_config" I have added a file "mpv.conf" where is written: "load-scripts=yes".
In this way, MPV.Net should load the files . LUA in "Scripts" folder.
The program doesn't load .LUA.
What's wrong?
Thanks.
Results 1 to 1 of 1
mpv.net media player
By stax76 in forum Software PlayingReplies: 91Last Post: 2nd Jan 2024, 05:03 -
Video download from Bunny (b-cdn.net or mediadelivery.net)
By tadkozh in forum Video Streaming DownloadingReplies: 6Last Post: 27th Nov 2023, 16:01 -
mpv.net sometimes stops working
By UserName351 in forum Software PlayingReplies: 0Last Post: 11th Mar 2022, 10:17 -
Is MakMKV.com Now MakeMKV.net or is .net Malicious?
By jdreffner in forum Blu-ray RippingReplies: 5Last Post: 25th Apr 2021, 14:05 -
Need help with mpv.net
By Dark Magician in forum Software PlayingReplies: 2Last Post: 18th Aug 2020, 04:20
