They play slow because of the method of Pal to NTSC conversion used by the distributor. Is there a way to rip these for burning on to a DVD+RDL so they can play at their proper speed? I understand Reclock will slow down playback of UK editions originally released in the US which use a method of NTSC to Pal conversion which speeds everything up. But in my case, I need something which will do the opposite of Reclock and apply to ripping, not just playback.
If the video is played back slower than the original, then a conversion from 25 fps (PAL, UK) to 23.976 fps (NTSC, US) has been made.
You can undo this with clever FFmpeg-GUI, without re-encoding.
First rip the video from your DVD.
Then start clever FFmpeg-GUI and load the ripped NTSC video, click main page, click various, click change framerate. Enter 25 for new fps and click change.
Wait until the conversion is finished.
[Attachment 87134 - Click to enlarge]
Then click on encode audio stream, select the encoder, under change length & pitch select preset FPS 23.976 -> 25 and click encode.
[Attachment 87135 - Click to enlarge]
Then click on multiplex, select the two new streams (in green) on the left, deselect the other streams, select the container and click multiplex.
[Attachment 87136 - Click to enlarge]
Done. You have a new 25 fps video in your destination folder. -
Why do plenty of US DVD releases of UK titles play at proper speed even when converted from Pal video to NTSC video?
VideoInspector - 2.15.8 ( Released 2022-03-04 )
By Kyle_Katarn in forum Latest Video NewsReplies: 1Last Post: 5th Feb 2023, 10:18 -
DVDLogic BD Wizard v1.0 released!
By DVDLogic in forum Latest Video NewsReplies: 8Last Post: 19th Sep 2021, 22:02 -
All-new DVDFab 12 has been Released!
By DVDFab Staff in forum Latest Video NewsReplies: 0Last Post: 10th Oct 2020, 11:20 -
Ignition - 2.26.2 ( Released 2020-09-27 )
By Kyle_Katarn in forum Latest Video NewsReplies: 0Last Post: 27th Sep 2020, 14:04 -
VideoInspector - 2.15.5 ( Released 2020-09-25 )
By Kyle_Katarn in forum Latest Video NewsReplies: 0Last Post: 25th Sep 2020, 16:41
