Hi I need some help with this question if anyone can help me with this
Does anyone know of any software that will split and convert like a 4 minute WAV file to a 5 second WAV file parts. I have got some WAV files that are like 4 minutes long of sounds and what I want to do if it can be done is can I split and convert like a 4 minute WAV file into parts like 5 second WAV audio files parts. I can do this manual with AudaCity but doing this with like over 50 WAV 4 minute files would take ages to do I know that when you convert video files you can leave a software to convert a load of video files but this is audio files. and I want to split like a 4 minute WAV file into like 5 second wav files is there any software that will do this instead of doing this manual file by file. like is there a converter we’re you put in like how long you want your audio file to be and it splits it into parts I don’t know of any software that will do this only doing it manual with audacity one file at a time which does take ages to do any help will do.
Results 1 to 10 of 10
Something like:
Code:ffmpeg.exe -i input.wav -codec copy -f segment -segment_time 5 -reset_timestamps 1 "output%%03d.wav"
If you have a lot of files, create a batch file (.bat in the folder with the files). It will check the entire folder for wav files, cut each of them into 5-second fragments, and place them in separate folders.
Code:@echo off setlocal enabledelayedexpansion for %%f in (*.wav) do ( set "filename=%%~nf" mkdir "!filename!" 2>nul ffmpeg -i "%%f" -f segment -segment_time 5 -c copy "!filename!\!filename!_%%03d.wav" )
Hi LISTYDOM How DO I CREATE A BATCH FILE THEN I have got over a 100 WAV audio files how do I do that then
I just wanted to test the codes.
I could not get either the code or the .bat to work.
I need a better guide & I believe the OP does too. -
It seams to work, as was explained
-put ffmpeg.exe into windows PATH or into the folder where wav files are
-create bat file, by creating a txt file in notepad, paste that posted text and rename it to something.bat, put that bat into folder where those wav files are
-run that bat by double clicking it or right click it and press Run -
but I'd recommend to tweak ListyDoM script to just call a function instead of using enabledelayedexpansion, it is a good habit to call functions.
Code:@echo off for %%f in (*.wav) do call :split_wav_files "%%f" echo press any key to exit&pause>nul&exit :split_wav_files <some wav file which becomes %1 in this function> set "filename=%~n1" mkdir "%filename%" 2>nul ffmpeg -i "%~1" -f segment -segment_time 1 -c copy "%filename%\%filename%_%%03d.wav" goto :eof
@ _Al_,
The Code you posted worked fine.
I did change the -segment_time 1 to -segment_time 5 to get the 5 seconds the OP wanted.
The code or script ListyDoM did not work foe me. -
If there is "!" character in names, it does not work, if using enabledelayedexpansion, otherwise not sure what is going on.
Question convert WAV files to vag files software needed
By barry25 in forum Software PlayingReplies: 1Last Post: 6th Feb 2025, 13:31 -
OpenShot won't play. wav file
By Ross Milburn in forum AudioReplies: 1Last Post: 19th Dec 2024, 03:07 -
trim a wav file by time stamp
By loninappleton in forum AudioReplies: 2Last Post: 23rd Jan 2023, 01:23 -
how to create a .wav file empty correspondant to a video-only file?
By marcorocchini in forum Newbie / General discussionsReplies: 19Last Post: 22nd Jul 2022, 15:11 -
How to convert WAV [PCM] to FLAC file?
By ConverterCrazy in forum Newbie / General discussionsReplies: 7Last Post: 14th Nov 2021, 10:19
