Results 1 to 19 of 19
  1. what happened is...
    1. it turned into Result.MOV but good thing the audio is working but without display
    2. I renamed my .RSV file to .MP4 and still the same Result.MOV also audio still working without display. I tried using VLC (Audio is playing) but it said Codec not Supported.
    HELP ((((
  2. Post a mediainfo report (text mode) from this video here.
  3. You can try to repair the file with VLC.
    Open the VLC player, click on Media, click on convert/save,
    drag your rsv file into the window, click convert, enter the target file and click start.
    Wait until the conversion is finished.
    Check the new mp4 file at the destination.
    [Attachment 87115 - Click to enlarge]
  4. thanks for the reply. its still the same.. there's still no display, only Audio, and the file size shrank from 29gb to 149mb. my bad for not mentioning the details.
    here's my video details from properties.
    This is the same video file type 10bit H.264 Slog 3 footage from the Sony A7IV. The >RSV file doesn't have any video details, so i just based it on another video that was on the SD card, which was fine and had the same setting.
    [Attachment 87125 - Click to enlarge]
  5. The try another way.
    Download untrunc (with gui) for your OS (32 Bit or 64 Bit) here:
    https://github.com/anthwlock/untrunc/releases/tag/latest
    Extract the zip and start untrunc-gui.exe
    Rename your .RSV file to .MP4.
    Drag this broken mp4 file into the truncated file field.
    Drag a working mp4 video form the same camera with the same settings into the reference file field.
    Then click Repair.
    [Attachment 87126 - Click to enlarge]
  6. It looks like it's almost there. There's already a preview, but the video isn't moving. I'm using VLC Player, but when I try Windows Media Player or QuickTime, i got these error notes.
    [Attachment 87127 - Click to enlarge]
    [Attachment 87128 - Click to enlarge]
  7. Retry with untrunc-gui.
    Click on settings and check skip unknown.
    Then retry the repair.
    [Attachment 87133 - Click to enlarge]
  8. still the same. is there any way to fix this
  9. Originally Posted by Lumingming View Post
    Load the rsv file into a hex editor and post the image here.
  10. Is this what you mean? Sorry, I don't know the hex editor. But here are the notes after I repaired it using UntruncGUI.
    [Attachment 87146 - Click to enlarge]
    And then, this is the setting you taught me.
    [Attachment 87147 - Click to enlarge]
    These are the notes using the .mp4 file that I renamed from .RSV.
    [Attachment 87148 - Click to enlarge]
  11. Originally Posted by Lumingming View Post
    This is a picture from a mp4 video loaded into a hex editor.
    [Attachment 87149 - Click to enlarge]
    In this sample I've used HxD, a free hex editor.
    You can download it here:
    https://mh-nexus.de/downloads/HxDPortableSetup.zip
    BTW:
    The info in your pic above looks good. Untrunc seems to have found video data, 33min 55sec long
  12. Thanks.. here you go.
    [Attachment 87153 - Click to enlarge]
    But the video still won't play—it just stays frozen, though there's a preview. However, my reference video plays just fine, and they have the same settings.
  13. Originally Posted by Lumingming View Post
    Post a pic from the good reference mp4 in the hex editor too.
  14. Originally Posted by Lumingming View Post
    Open the rsv file too (both files should be open).
    Select the good mp4.
    Select all from offset 0 to offset C0 (12 rows) and click Edit (in the menu), copy.
    Select the rsv file now.
    Point to offset 0 (first byte), click edit, past insert.
    Then click file, save as (save as new mp4 file, so the source remains untouched).
    Close both files with the X below (top, right, NOT toppest X), then close Hxd.
    Repeat the untrunc action with the new created mp4 as bad file.
    btw:
    The good.mp4 contains video? It seems to be empty.
  15. i'm still trying to figure it out. lol
    i've shot the good.mp4 video with lens cup on i didn't expose the correct way for Slog 3 but it has the same setting. is it affecting the video details?
  16. Originally Posted by Lumingming View Post
    HELP
    I am developing my own utility for recovering unfinalized video files. And I am interested in testing it on real cases. Could you try to recover your file with it? The utility is commercial, but it can save the first five minutes of the recovered video as a demonstration. If these five minutes are recovered correctly, then you can know for sure that the file can be recovered. Link.
  17. Originally Posted by Lumingming View Post
    Yes of course, as good.mp4 you should take a video that corresponds as closely as possible to bad.rsv
  18. got you. but does it have to be the same duration too?
