  1. hello
    i have a 2 folder a BDMV and Certificate folders im trying to burn it on a blu ray disc but there some issue
    i also try to import the files from steam folder into nero and at some point 2 of the file are very small and get an error : Unable to insert %1
    the file is 156KB and the other are like 2gb and mores
    what software i can use to recreate the bluray ?
  2. Those small files are usually critical for Blu-ray compliance. If you need to reauthor the structure (in case files are corrupted or misaligned), DVDFab Blu-ray Creator can rebuild the Blu-ray properly. But if your folders are intact, ImgBurn (free) should work. Just load the BDMV/CERTIFICATE folders, select Build mode, and make sure the output is set to Blu-ray UDF 2.50/2.60.
  3. Originally Posted by kerm007 View Post
    .... what software i can use to recreate the bluray ?
    BD Rebuilder
  4. hello
    it's a Bray that i download from the net
