  1. I am trying to dump CDM from my Samsung Galaxy J6+ but no success with KeyDive or dumper.
    Following all KeyDive instructions to install and run (provision Widevine, Refresh, Test DRM Playback inside Kaltura), the video gets stuck on 00:00-01:00.
    When I try Bitmovin it shows error: The MediaKey object could not be created/initialized (DRM_MEDIA_KEY_INITIALIZATION_FAILED).
    Following the log, it seems to find the necessary info, but the files are not generated, also videos don't load.
    Tried the old dumper, it runs the videos but only retrieves me ---RSA PRIVATE KEY--- on terminal, but no files or other information generated.
    The phone had a custom ROM but I flashed stock ROM.
    Tried on windows and Mac, same result.
    Tried reporting issue on GitHub and contacting KeyDive developer on Discord, no reply.
    Following the log, I will change some info that I think are sensitive.
    Any help will be appreciated!
    (venv) caiopinho@MacBook-Air-de-Caio keydive % keydive -kwp
    2025-05-15 19:16:32 [I] KeyDive: Version: 2.2.1
    2025-05-15 19:16:32 [I] ADB: Connected to device: SM J610G (8b8fe4fc)
    2025-05-15 19:16:32 [I] ADB: SDK API: 29
    2025-05-15 19:16:32 [I] ADB: ABI CPU: armeabi-v7a
    2025-05-15 19:16:32 [I] Core: Hook script prepared successfully
    2025-05-15 19:16:32 [I] KeyDive: Starting application: com.kaltura.kalturadeviceinfo
    2025-05-15 19:16:32 [I] KeyDive: Setup completed
    2025-05-15 19:16:32 [I] KeyDive: Watcher delay: 1s
    2025-05-15 19:16:32 [W] Core: Library not found: libwvdrmengine(?:@\S+)?\.so
    2025-05-15 19:16:33 [W] Core: Library not found: libwvdrmengine(?:@\S+)?\.so
    2025-05-15 19:16:33 [I] Core: Library: libwvhidl.so (/vendor/lib/libwvhidl.so)
    2025-05-15 19:16:35 [I] Script: Library liboemcrypto.so (/vendor/lib/liboemcrypto.so) has been disabled
    2025-05-15 19:16:35 [I] KeyDive: Process: 22005 (android.hardware.drm@1.2-service.widevine)
    2025-05-15 19:16:35 [I] KeyDive: Successfully hooked
    2025-05-15 19:16:55 [W] KeyDive: Widevine process has changed
    2025-05-15 19:16:55 [W] Core: Library not found: libwvdrmengine(?:@\S+)?\.so
    2025-05-15 19:16:55 [W] KeyDive: Widevine library not found, searching...
    2025-05-15 19:16:57 [W] Core: Library not found: libwvdrmengine(?:@\S+)?\.so
    2025-05-15 19:16:57 [I] Core: Library: libwvhidl.so (/vendor/lib/libwvhidl.so)
    2025-05-15 19:16:59 [I] Script: Library liboemcrypto.so (/vendor/lib/liboemcrypto.so) has been disabled
    2025-05-15 19:16:59 [I] KeyDive: Process: 24051 (android.hardware.drm@1.2-service.widevine)
    2025-05-15 19:16:59 [I] KeyDive: Successfully hooked
    2025-05-15 19:17:13 [W] KeyDive: Widevine process has changed
    2025-05-15 19:17:13 [W] Core: Library not found: libwvdrmengine(?:@\S+)?\.so
    2025-05-15 19:17:13 [W] KeyDive: Widevine library not found, searching...
    2025-05-15 19:17:14 [W] Core: Library not found: libwvdrmengine(?:@\S+)?\.so
    2025-05-15 19:17:15 [W] Core: Library not found: libwvdrmengine(?:@\S+)?\.so
    2025-05-15 19:17:15 [I] Core: Library: libwvhidl.so (/vendor/lib/libwvhidl.so)
    2025-05-15 19:17:17 [I] Script: Library liboemcrypto.so (/vendor/lib/liboemcrypto.so) has been disabled
    2025-05-15 19:17:17 [I] KeyDive: Process: 24130 (android.hardware.drm@1.2-service.widevine)
    2025-05-15 19:17:17 [I] KeyDive: Successfully hooked
    2025-05-15 19:17:29 [W] KeyDive: Widevine process has changed
    2025-05-15 19:17:30 [W] Core: Library not found: libwvdrmengine(?:@\S+)?\.so
    2025-05-15 19:17:30 [I] Core: Library: libwvhidl.so (/vendor/lib/libwvhidl.so)
    2025-05-15 19:17:33 [I] Script: Library liboemcrypto.so (/vendor/lib/liboemcrypto.so) has been disabled
    2025-05-15 19:17:33 [I] KeyDive: Process: 24227 (android.hardware.drm@1.2-service.widevine)
    2025-05-15 19:17:33 [I] KeyDive: Successfully hooked
    2025-05-15 19:17:34 [W] KeyDive: Widevine process has changed
    2025-05-15 19:17:34 [W] Core: Library not found: libwvdrmengine(?:@\S+)?\.so
    2025-05-15 19:17:35 [W] Core: Library not found: libwvdrmengine(?:@\S+)?\.so
    2025-05-15 19:17:35 [I] Core: Library: libwvhidl.so (/vendor/lib/libwvhidl.so)
    2025-05-15 19:17:37 [I] KeyDive: Process: 24329 (android.hardware.drm@1.2-service.widevine)
    2025-05-15 19:17:37 [I] KeyDive: Successfully hooked
    2025-05-15 19:18:20 [I] Keybox: Receive device id:
    "SECPHONE_0000000000000000_7_NUMBERS_EDITED"
    "Yq{DaaszTywtQcnyvZiMp\u0000" (10 CHARACTERS DELETED)
    2025-05-15 19:18:20 [I] Keybox: Receive keybox:
    "device_id": "Yq{DaaszTywtQcnyvZiMp\u0000" (10 CHARACTERS DELETED),
    "device_key": "JNW5YekmQDzA==" (10 CHARACTERS DELETED),
    "device_token": "UsJSz1VA5dVppxx4GENJP0qrz3horOYQQZ3k+S+GiNo9eqKMM 5ZHJ9eOLvaSYgykbDWnx4KVQl48" (20 CHARACTERS DELETED),
    "keybox_tag": "kbox",
    "crc32": 18893 (5 NUMBERS DELETED),
    "level_tag": null,
    "flags": 13895 (5 NUMBERS DELETED),
    "system_id": 14301 (5 NUMBERS DELETED),
    "provisioning_id": "781c79-438-3f9-4aab-cf78b0" (10 CHARACTERS DELETED),
    "encrypted_bits": "po9rTOPYMQkQcZO3pk+S+GiNo9eqviIYybWnx4KVQl48" (20 CHARACTERS DELETED)
    2025-05-15 19:18:20 [W] Keybox: Keybox contains encrypted data. Interception of plaintext device token is needed
    2025-05-15 19:18:21 [W] KeyDive: Widevine process has changed
    2025-05-15 19:18:21 [W] Core: Library not found: libwvdrmengine(?:@\S+)?\.so
    2025-05-15 19:18:21 [E] Core: unable to find process with pid 24472
    2025-05-15 19:18:21 [W] KeyDive: Widevine library not found, searching...
    2025-05-15 19:18:22 [W] Core: Library not found: libwvdrmengine(?:@\S+)?\.so
    2025-05-15 19:18:23 [W] Core: Library not found: libwvdrmengine(?:@\S+)?\.so
    2025-05-15 19:18:23 [I] Core: Library: libwvhidl.so (/vendor/lib/libwvhidl.so)
    2025-05-15 19:18:26 [I] KeyDive: Process: 24479 (android.hardware.drm@1.2-service.widevine)
    2025-05-15 19:18:26 [I] KeyDive: Successfully hooked
    2025-05-15 19:18:28 [W] KeyDive: Widevine process has changed
    2025-05-15 19:18:28 [I] Cdm: Receive private key:
    -----BEGIN RSA PRIVATE KEY----- (15 LINES DELETED)
    MIIEpAIBAAKCAQEAk89b0Ujp2k4BoNR0IWMg4abULpvilgsTOl Bke2w4CikiDYvy
    fFYUz73eYnxmChlYTfu21dHy+R3Ka2R1hYztvKDkReGN63bBUP qGBANREyvjds48
    nMIGun5rsbp0DjyWbQExFw6rw3Ke5QqRt4eqgjZ2VT8jHRmSEU i4/yCoyjzIflza
    G5iY6B1+2sPHxXnlQ8+Im9LMtCwcdTsmQT0nqLWDEgELNm93sf A2gMOA62T1Vcm/
    1FB/bSWJj/gLAE3JQiUKqJnln28SB3pwufNNCKxSaB6NMZdqsp32vVFhKOPa nAYb
    0Amht44/xx2zkGujmhcKsmDnTQVNlptRtH22CVNmpoesxLXcUFi4AO734Q Ar6Bhv
    1Xr9RWpupYB6Us9k73vOXgrasq1UB/Ks90pH5sxnoEQn4462cQQ2OK9NT4EYa9XR
    RdxNgQKBgQDMPVr4JTNEMllfHzy6nS9D4Q1PtzCDLbVyHNhvU/+JFLf8gx3tWVEG
    hgtnPKGbPgpjIBR32U25rlghT1j4pl+51rvcqtPWBty2k0oNwO ZWvnMJZBQi4fpp
    I/LB1kBPqKATFvCuhdqI+K95YUhgMlV60x8FcmtHfslu9JuvfPU8 Dg==
    -----END RSA PRIVATE KEY-----
    2025-05-15 19:18:28 [W] Cdm: The function 'kyszdimm' does not belong to the referenced functions. Communicate it to the developer to improve the tool.
    2025-05-15 19:18:29 [W] Core: Library not found: libwvdrmengine(?:@\S+)?\.so
    2025-05-15 19:18:29 [E] Core: unable to find process with pid 24604
    2025-05-15 19:18:29 [W] KeyDive: Widevine library not found, searching...
    2025-05-15 19:18:31 [W] Core: Library not found: libwvdrmengine(?:@\S+)?\.so
    2025-05-15 19:18:31 [I] Core: Library: libwvhidl.so (/vendor/lib/libwvhidl.so)
    2025-05-15 19:18:34 [I] KeyDive: Process: 24611 (android.hardware.drm@1.2-service.widevine)
    2025-05-15 19:18:34 [I] KeyDive: Successfully hooked
    2025-05-15 19:18:35 [W] KeyDive: Widevine process has changed
    2025-05-15 19:18:36 [W] Core: Library not found: libwvdrmengine(?:@\S+)?\.so
    2025-05-15 19:18:36 [E] Core: unable to find process with pid 24664
    2025-05-15 19:18:36 [W] KeyDive: Widevine library not found, searching...
    2025-05-15 19:18:37 [W] Core: Library not found: libwvdrmengine(?:@\S+)?\.so
    2025-05-15 19:18:38 [W] Core: Library not found: libwvdrmengine(?:@\S+)?\.so
    2025-05-15 19:18:38 [I] Core: Library: libwvhidl.so (/vendor/lib/libwvhidl.so)
    2025-05-15 19:18:41 [I] KeyDive: Process: 24670 (android.hardware.drm@1.2-service.widevine)
    2025-05-15 19:18:41 [I] KeyDive: Successfully hooked
    2025-05-15 19:18:50 [W] KeyDive: Widevine process has changed
    2025-05-15 19:18:50 [W] Core: Library not found: libwvdrmengine(?:@\S+)?\.so
    2025-05-15 19:18:51 [I] Core: Library: libwvhidl.so (/vendor/lib/libwvhidl.so)
    2025-05-15 19:18:53 [I] KeyDive: Process: 24734 (android.hardware.drm@1.2-service.widevine)
    2025-05-15 19:18:53 [I] KeyDive: Successfully hooked
    2025-05-15 19:27:34 [W] KeyDive: Widevine process has changed
    2025-05-15 19:27:34 [W] Core: Library not found: libwvdrmengine(?:@\S+)?\.so
    2025-05-15 19:27:35 [W] Core: Library not found: libwvdrmengine(?:@\S+)?\.so
    2025-05-15 19:27:35 [E] Core: unable to find process with pid 26461
    2025-05-15 19:27:35 [W] KeyDive: Widevine library not found, searching...
    2025-05-15 19:27:36 [W] Core: Library not found: libwvdrmengine(?:@\S+)?\.so
    2025-05-15 19:27:36 [I] Core: Library: libwvhidl.so (/vendor/lib/libwvhidl.so)
    2025-05-15 19:27:38 [I] KeyDive: Process: 26466 (android.hardware.drm@1.2-service.widevine)
    2025-05-15 19:27:38 [I] KeyDive: Successfully hooked
    2025-05-15 19:29:32 [W] KeyDive: Widevine process has changed
    2025-05-15 19:29:32 [W] Core: Library not found: libwvdrmengine(?:@\S+)?\.so
    2025-05-15 19:29:32 [W] KeyDive: Widevine library not found, searching...
    2025-05-15 19:29:34 [W] Core: Library not found: libwvdrmengine(?:@\S+)?\.so
    2025-05-15 19:29:34 [I] Core: Library: libwvhidl.so (/vendor/lib/libwvhidl.so)
    2025-05-15 19:29:36 [I] KeyDive: Process: 26865 (android.hardware.drm@1.2-service.widevine)
    2025-05-15 19:29:36 [I] KeyDive: Successfully hooked
  2. No one can help me?
    Any tought?
  3. I searched this phone pub on 2018, usually Samsung phone has L1, so you need check your phone drm level, ensure it's L3. then root your phone.
