I used pinnacle when it first came out and it was very easy to use. I am trying 26 trial but it will not load my old files from version 12 or 14, I don't remember. The program hangs and then crashes. I'm considering buying an old version pinnacle studio 12, as I hear it was the last solid version? But will it run on windows 11? I am re-editing 100 old videos and having all the old work already done for me (I will be making some changes) will save me months of work. To be clear: Ten years ago I saved the projects and I have all of those projects saved along with the original captured video. Pinnacle claims these can be loaded to version 26 but they do not load so I either need to find a way to load these to 26 or find a way to get version 12 which is more than 10 years old, and use it on my windows 11. I'm sure the old saved projects will load in version 12.
	I have removed Pinnacle 24 from my computer because I wasn't using it on a regular basis. Just out of curiosity are you using File > Import previous Pinnacle Studio Projects?
  Pinnacle Studio 20 questionBy dillsley@aol.com in forum Newbie / General discussionsReplies: 19Last Post: 25th Nov 2024, 13:18
  Help With Pinnacle Studio 26By Magnum Arts in forum EditingReplies: 2Last Post: 25th Sep 2024, 19:58
  Export into 5.1 audio with Pinnacle Studio 21.By Seek&Create in forum AudioReplies: 0Last Post: 29th Apr 2024, 15:17
  Pinnacle studio movie box HDBy hdfills in forum Capturing and VCRReplies: 2Last Post: 7th Feb 2022, 16:25
  Pinnacle Studio 12 activation in 2021By SmurfRecorder in forum ComputerReplies: 3Last Post: 30th Mar 2021, 05:15
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
