Hi
I would like to download some videos on NPO start. I am on Macos Sequoia and have a NPO plus account.
I would like to download this one and the others in that series: https://npo.nl/start/serie/eva/seizoen-1/eva_133/afspelen
Can you please tell me what info and tool I need to get this downloaded? I read around these pages that I need a key but I am not sure how to get it and how to use that key in which tool to download it eventually.
Can you please help?
				Results 1 to 11 of 11
	did you tried these two tools?
 Code:https://forum.videohelp.com/threads/416316-%5BRelease%5D-WidevineProxy2-Extension-Bypass-HMAC-1-timetokens-Lic-wrapping https://forum.videohelp.com/threads/414548-drm-free-content-batch-downloader-widefrog
	Hi thanks for the reply. As I tried to understand from different threads, I need to use N_m3u8DL-RE and for that I need the mpd link and the decryption key to download the video. I have the mpd link, I am trying to get the decryption key. I just tried the first link (WidevineProxy2) to install the extension to get the info like PSSH needed to get the decryption key. It seems there are already ready-to-use 30 Widevine devices. I downloaded one of them, the first one. It was a zip file I extracted it and it is now a folder. But when I go the extension on my Brave browser, I try to select the Widevine device from that folder I downloaded but it can't select anything. I am not sure if this works in Macos but I think it should.
 Kindly asking for further instructions on how to proceed.
	then you got a .wvd file, import it in widevine proxy2Code:pip install pywidevine pywidevine create-device -t ANDROID -l 3 -k "key path on your pc" -c "client path on your pc"
	WHat is the key path and client path? How do I find them? Btw, if possible, I want to use a ready-to-use device, one of the files from this link. (https://forum.videohelp.com/threads/413719-Ready-to-use-CDMs-available-here%21)
	once you unzip that file you downloaded from the link you posted, you will see two file, one is key and another is client(blob?). then you know how to get the path(means where they're on your pc), right?
	yes thanks I got the key now. I tried to put the code of N_m3u8DL-RE into the terminal (as in this format:N_m3u8DL-RE "https://npo-nl-ams-p16-am3.cdn.streamgate.nl/TOKEN/vod/npo/usp/TEST/npo/dash_cenc/AT_300017348/AT_300017348_v1720387759.ism/stream.mpd" --save-name "Festival der Liebe" -sv best -sa all -ss all -mt -M mkv --key 162c6f4514a2a92a88f01363c8466c06:34191ca89bf2a8317 518ac5277c29b3e)
 But when I downloaded the zip of N_m3u8DL-RE from github for Macos Arm64 (I am using m2), I unzip and it gives me a exe file which Macos does not recognize. I could not get N_m3u8DL-RE to start working.
	I'm not familiar with Mac os, but I think you downloaded wrong file, you need check from github again.
	this one should be the correct one for your os: https://github.com/nilaoda/N_m3u8DL-RE/releases/download/v0.3.0-beta/N_m3u8DL-RE_v0.3....0241203.tar.gz
  Download from NPOBy daybreak in forum Video Streaming DownloadingReplies: 40Last Post: 7th Oct 2025, 18:43
  npo.nl requestBy Lupine Assassin in forum Video Streaming DownloadingReplies: 3Last Post: 18th Feb 2025, 10:37
  Download from NPOBy sven32 in forum Video Streaming DownloadingReplies: 92Last Post: 10th Dec 2024, 05:04
  NPO streamBy Brokje1988 in forum Video Streaming DownloadingReplies: 3Last Post: 7th Feb 2024, 15:31
  hello everyone need some videos from npoBy forbiddenlove1 in forum Video Streaming DownloadingReplies: 3Last Post: 7th Dec 2023, 14:38
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
