Results 1 to 10 of 10
    Oct 2018
    Town Spa Pizza, United States
    Hello Forum.
    Before I go on, I will just say after many attempts to grasp PAR, SAR and DAR, blessings to all who get it.
    Anyway, for simplicity's sake and so my head doesn't explode, I capture lossless at 720x480>Crop and deinterlace in Hybrid (other filters as needed) to 704x480.
    Then using I render to lossless 704x480, deliver in PowerDirector as MP4, 704x480 60P bobbed from 29.97 capture. The files play perfectly fine in everything including my LG smarty TV, tablet, PC on Facebook, thumb drive everywhere. No client has ever complained.
    Is here any reason that 704 is so uncommon? Should I be cropping to 704 but delivering as 640?
    If it doesn't seem to be broke, don't fix it, but am I doing something inadvisable?
  2. Cropping captured analog video to 704x480, encode and play it as 4:3 is perfectly right.
    Oct 2018
    Thank you, Sharc, I have been searching and searching here there and everywhere for a definitive answer. Why is it so uncommon? My simple mind just figured capture non-square, deliver non-square, less conversion but I'm certain that reveals my lack of fully understanding, it's probably meaningless. OK, at least I can rest easy I am not doing something terrible.
  4. Originally Posted by Barrythecrab View Post
    It's not uncommon. It is the standard (Rec.601) for analog capturing, rounded to practical digital values (704 being mod16 compliant).
    Jan 2016
    Resize to 1440x1080 and all your worries go away, If de-interlaced properly, TVs and media players wouldn't have to do anything but display the pixels or double line if you have a 4K TV.
    Jun 2024
    For Facebook or YouTube shouldn't he be using square pixels?
  7. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    Not really; for YouTube we upscale to a HD resolution (i.e. 1440x1080) to get better treatement, which incidentally is a square pixel format.
    For Facebook we generally use 1280x720.
    In other words, square pixel is not a requirement.
    704x576 (or 704x480) are the final resolution to use while staying in SD resolutions, as Sharc proprely said, adding a 4:3 DAR.
    Jun 2024
    Okay now i'm confused. So for YouTube and Facebook non square pixel aspect ratios are fine?
  9. Capturing Memories dellsam34's Avatar
    Jan 2016
    Are fine as long as an AR flag is provided in the encoded video, otherwise YT or FB wouldn't know what shape the pixels are and display them as square pixels with distorted frames, Haven't you seen enough of those distorted videos already online?
    Jun 2024
    Yes, I have. Okay I got what you are saying.
