Hello,
I am getting issues with files I have converted from bdmv to iso and then burning them. With the final result, the panasonic udp900 player can sometimes have out of sync audio and artifacts on the screen. I am using a pioneer bdr-s12u writer. I am using verbatim bd-r discs.
I use Nero or imgburn to burn the discs. Is there a way to check the integrity of the BDMV folder before I burn? or is there something else I can do?
Results 1 to 1 of 1
BluRay Player with BDXL Support
By Jake802 in forum DVD & Blu-ray PlayersReplies: 565Last Post: 21st Nov 2025, 12:54 -
NTSC VHS -> x2 AI Upscaler -> Author to BDXL: Handling resolution and AR
By wubikens in forum Authoring (Blu-ray)Replies: 8Last Post: 4th Oct 2024, 04:12 -
burning 4k iso to bdxl blurays
By frankpickles in forum Newbie / General discussionsReplies: 4Last Post: 27th Feb 2024, 22:40 -
BDXL 55GB MKV File
By michaelsft in forum Authoring (Blu-ray)Replies: 2Last Post: 8th Mar 2021, 09:50 -
Panasonic SUPER VHS video player NV-HS960B
By hdfills in forum Newbie / General discussionsReplies: 4Last Post: 12th Jul 2020, 17:27
