[Attachment 86865 - Click to enlarge]
URL: https://music.apple.com/cn/album/magic-man/1766382845
You need to log in to an Apple account, otherwise the audio will not be complete.
m3u8 URL: https://aod-ssl.itunes.apple.com/itunes-assets/Music211/v4/62/89/b9/6289b9e3-7f10-48ec...hq.aac.wa.m3u8
key in m3u8.file:
#EXT-X-KEY:METHOD=ISO-23001-7,URI="data:;base64,AAAAAGlI3QYAHb04q+XU8g=="
The downloaded M3U8 music file has no sound, it is encrypted.
Who can help me and guide me? What is ISO-23001-7 and how to decrypt using the key here?
just use widevine proxy2 or https://github.com/zhaarey/apple-music-downloader (the second one gets also alac but it's slighty more complicated to setup)
WidevineProxy2 works.
Don't forget to put L3 Cdm in the extension.
[Attachment 86929 - Click to enlarge]
Use StreamDetector Addon to get the link
[Attachment 86930 - Click to enlarge]
Some sites do the job to download Apple Music...
https://aaplmusicdownloader.com/Last edited by cedric8528; 10th May 2025 at 02:18.
Ah, WidevineProxy2 worked! I didn't think it would work because I saw an error, but it really does work. Thank you so much!!!
[Attachment 86946 - Click to enlarge]
I obtained the key, but when using the command line N_m3u8DL-RE "undefined" --key 000000006948dd06001dbd38abe5d4f2:d20bb0c49382c40ce 75ba83d1795c86f --use-shaka-packager -M format=mkv, it shows the error "ERROR: Object reference not set to an instance of an object."
[Attachment 86947 - Click to enlarge]
I tried downloading the MP4 through the m3u8 file and then using mp4decrypt to decrypt it, but I found that the decrypted audio is still not playable.
Sorry, I had some difficulty with reading comprehension... I carefully reviewed what you said, and by adding the N_m3u8DL-RE command to the m3u8, it worked! I used the command N_m3u8DL-RE https://aod-ssl.itunes.apple.com/itunes-assets/Music211/v4/62/89/b9/6289b9e3-7f10-48ec...hq.aac.wa.m3u8 --key 000000006948dd06001dbd38abe5d4f2:d20bb0c49382c40ce 75ba83d1795c86f --use-shaka-packager -M format=mkv, and it successfully downloaded and decrypted the audio. Thanks again for your help!
[Attachment 86948 - Click to enlarge]Last edited by pein; 11th May 2025 at 23:41. Reason: Additional information
Any way to download out of reigon Apple Music videos?
By paul92 in forum Video Streaming DownloadingReplies: 8Last Post: 16th Aug 2024, 07:32 -
Apple Music - Please assist
By paul92 in forum Video Streaming DownloadingReplies: 16Last Post: 9th Aug 2024, 08:18 -
Need an Apple Music US reigon accountholder to please assist.
By paul92 in forum Video Streaming DownloadingReplies: 2Last Post: 16th Jun 2024, 03:10 -
Help with apple music ALAC Format
By hansoljun in forum AudioReplies: 0Last Post: 7th Mar 2024, 10:31 -
Extract loosless files from Apple Music
By alba77 in forum AudioReplies: 2Last Post: 9th Oct 2023, 18:03
