ok, i heard that you can't make vcd's using some cd-r media. is this true? if so, what brand of cd-r's is commonly used for vcds?
thx
The cdr media you use will depend on how picky your DVD player is, assuming you want to play them in a DVD player. My DVD player plays just about anything, although some are a little fussy. The best thing is to try a brand and see if it works. Check on the DVD compatability guide for any issues with cdr's that your player may have.
Craig -
brand of cd-r really doesn't matter very much...it's basically where it's manufactured...
ok ... decent = taiwan
really good = japan
so if a "brand" cd-r is made in taiwan, it's basically made by the same ppl who make those generic, cheapo, silver top cd-rs
Quick Question
By TagFan in forum DVB / IPTVReplies: 3Last Post: 26th Sep 2011, 10:45 -
converting to 3g2, anything better than Quick Media Converter?
By logic7 in forum Video ConversionReplies: 1Last Post: 28th Jan 2010, 04:19 -
Conversion with Quick Media Converter 3.6.0
By gjordan12198 in forum Video ConversionReplies: 1Last Post: 9th Jan 2009, 04:27 -
quick question?
By JRSWIFEY2004 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jan 2008, 17:38 -
Quick Question
By Scryer_360 in forum Newbie / General discussionsReplies: 3Last Post: 26th Dec 2007, 08:21
