Youtube has some tool that translates nearly instantly for their comments section.
I have some video in French language but ultimately want to make and English sub using free tools available.
There is another version of this piece with Greek subs (and French language) but those are hard coded, at least the subs do not show up in MediaInfo.
[edit] I see that I have asked a similar question already. But I still need to know what's available currently.
Results 1 to 11 of 11
Hello again and thanks for answering. No this is not Youtube but a regular mkv file.
If Whisper can translate and make the subtitles it would be a solution.
Or if the subs that are on one of the versions of the video were not hard-coded I wouldn't be thinking of multiple steps. I know Whisper can get text and I know that Subtitle Edit can translate fairly well. We've mentioned before that using a Python version of Whisper with command line is something I cannot do without (a lot) of assistance and I'll avoid that.
I've had problems with Whisper in the past perhaps for lack of clarity in the audio. So have there been any major Whisper upgrades and can it work slower on older CPUS? I have a dedicated PC that can run long jobs but it is pretty old with Phenom 4 core and onboard video MSI 760gm otherboard. I know this is a lot of old ground if there have not been new developments. The video is a Proshot of a live play. It's in French and the subtitles are in Greek since its performed at an ancient theatre in Greece by a French company. -
Your best option then is to extract the Greek hardcoded subtitles but it would be a long and painful process depending on the length of the video.
I can help you with my Whisper AI system if you like, preferably using a version without the Greek subtitles if you have it.
Just upload the file to your Google Drive and PM me the download link. -
Thanks for the offer.
I have to examine the two videos to select which one should be worked on. There may actually be a completed sub for this that others had mentioned but got lost over time (in the file share world.) My first look showed the one with the hard coded subs had better picture quality (but the file sizes are very close so maybe someone was experimenting at one time.) -
Working on that now. I hope Mediafire is ok.
I'm uploading to my account the full play with Greek Subs because it is overall better.
And I demuxed the audio to WAV using Goldwave. So those two things will be in a folder. I will pm when
the upload completes. My upload bandwidth is slow so will do soonest. -
OK Thanks for the update. Please send me the download link
Unfortunately due to health issues, I an not sure when I will be able to do this job, but will do it ASAP -
I completely understand and wish you a speedy recovery.
I will PM the link at Mega rather than Mediafire.Last edited by loninappleton; 9th May 2025 at 13:28.
Sent PM with srt download links.
Thank you very much for your good wishes. -
Subtitles and all
I had to let this project go for a reason. The voice to text got some English but I found that without a printed play script it is not possible to get good working English. The play was translated from the Greek to French in 1944 which I found from research. The director used that version and it was never re-released as English even though I think her translation is still in print. So it was a dead end.
I have a performance of Measure for Measure that has no subs. I'm going to try to use Whisper in Subtitle Edit to get some text from that. And with that I can of course find a print copy and see if I can bring the two together. It's a rare video proshot from capture and it has dropped frames from a live shoot. What the subtitle will do is print over the dropped frames part for continuity of the speeches. That's my goal anyway.
French to English using Subtitle Edit Auto Translate
By loninappleton in forum SubtitleReplies: 2Last Post: 6th Jun 2024, 15:18 -
French audio clip to French or English text
By loninappleton in forum SubtitleReplies: 26Last Post: 25th Jul 2023, 14:22 -
Redirect language DVD buttons to 1 language
By Anonymous847344 in forum Authoring (DVD)Replies: 15Last Post: 4th Dec 2022, 23:05 -
MPC - disable english subtitles when the audio is english
By Senai in forum SubtitleReplies: 1Last Post: 13th Apr 2022, 15:27 -
Merging english translation sub into english sub?
By bizzybody in forum SubtitleReplies: 0Last Post: 18th Feb 2021, 03:45
