As described in my previous threads, I've been trying to get a working script to de-interlace a mix of broadcast content.
I've used this script which achieves just about everything I'd like with the encodes:
Code:Import("TemporalDegrain-v2.6.6.avsi") # Load both audio and video in sync, explicitly set original FPS video_audio = FFmpegSource2("1_New_Raw_Sample", atrack=-1, fpsnum=30000, fpsden=1001).ConvertToYUY2().AssumeTFF() # Crop crop_left = 4 crop_top = 4 crop_right = 12 crop_bottom = 4 video_crop = video_audio.crop(crop_left, crop_top, -crop_right, -crop_bottom) # QTGMC at 59.94 fps processed = video_crop.AssumeTFF() processed = QTGMC(processed, preset="Slower") # Denoising denoised = processed.ConvertToYV16().TemporalDegrain2(degrainTR=1).ConvertToYUY2() # Sharpening (fixed) sharpened_yv12 = denoised.ConvertToYV12().LSFmod(defaults="slow") sharpened = sharpened_yv12.ConvertToYUY2().MergeChroma(denoised) # Restore borders # Calculate total cropped width/height total_crop_w = crop_left + crop_right total_crop_h = crop_top + crop_bottom # Calculate symmetrical borders border_left = total_crop_w / 2 border_right = total_crop_w - border_left border_top = total_crop_h / 2 border_bottom = total_crop_h - border_top # Round if needed (AviSynth expects integers) border_left = Round(border_left) border_right = Round(border_right) border_top = Round(border_top) border_bottom = Round(border_bottom) video_final = sharpened.AddBorders(border_left, border_top, border_right, border_bottom) # Convert to YV12 and output (audio already present) final_output = video_final.ConvertToYV12() final_output = final_output.ConvertFPS(60000, 1001) # Proper timing for 59.94 fps without desync final_output2 = final_output.Prefetch(20) return final_output21. Frame rate doubled to 59.94fps for smooth playback (retaining both live action and animation clarity)Code:ffmpeg -i script.avs -vf "setsar=10/11" -aspect 4:3 -c:v libx264 -preset slow -crf 18 -pix_fmt yuv420p -profile:v high -level 4.1 -rc-lookahead 40 -refs 4 -c:a aac -b:a 192k -movflags +faststart 2_New_Encoded_Sample.mp4
2. Slight noise reduction
3. Remove junk noise and empty space through cropping
4. Replace the cropped pixels with black pixels, retaining original dimensions of 720 x 480
5. Center the picture after cropping, for image symmetry
6. Encode at a faster speed (prefetch)
7. Encode at high-lossy with no visible difference to lossless
8. Encode at correct aspect ratio of 4:3
I'm hoping to move forward to this script for big batches (I have much of the same broadcast content), only modifying for variables such as field order and image cropping.
Although I'm really happy with the results, I'd be keen to know what others think? Personally I don't think there should be any more noise removal as it may start losing too much detail. Are there any other aspects I should consider?
Just looked at the script.
Why the whole 4:2:2 <> 4:2:0 conversions, when you aim for 4:2:0 for the output?
If you aim for 4:2:0 the restoring of the chroma after lsfmod and the YUY2<>YV16 conversions seem useless.
The ConvertFPS seems useless. Source is returned by the source filter @30000/1001fps and then doubled by QTGMC to 60000/1001.
Personally, I would crop after deinterlacing and not the other way around. (so even with 4:2:0 I can use mod2 cropping vertically)
You might want to do some testing, I assume using a lower prefetch value might be faster with the filters you use.
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
I've updated this script with some adjustments.
Code:Import("TemporalDegrain-v2.6.6.avsi") # Load source video_audio = FFmpegSource2("1_New_Raw_Sample_2.avi", atrack=-1, fpsnum=30000, fpsden=1001).AssumeTFF() # QTGMC at 59.94 fps processed = QTGMC(video_audio, preset="Slower") # Crop after deinterlacing crop_left = 4 crop_top = 4 crop_right = 12 crop_bottom = 4 cropped = processed.crop(crop_left, crop_top, -crop_right, -crop_bottom) # Denoise and sharpen in YV12 (this is to avoid unnecessary format switching) denoised = cropped.TemporalDegrain2(degrainTR=1) # Reconvert to YV12 due to TempDegrain output sharpened = denoised.ConvertToYV12().LSFmod(defaults="slow") # Restore borders border_left = Round((crop_left + crop_right) / 2) border_right = (crop_left + crop_right) - border_left border_top = Round((crop_top + crop_bottom) / 2) border_bottom = (crop_top + crop_bottom) - border_top restored = sharpened.AddBorders(border_left, border_top, border_right, border_bottom) # Output with prefetch return restored.Prefetch(12)
Also, I'm thinking about archiving the raw video captures using FFVI and FLAC, does this seem sensible?
I'm still open to suggestions on the above script before continuing the encoding process.
Fixing video that has already been improperly deinterlaced
By Master Tape in forum RestorationReplies: 2Last Post: 4th Mar 2025, 09:24 -
Restoring tapes - a mix of animation and live action commercials
By waxstone in forum RestorationReplies: 1Last Post: 7th Nov 2024, 12:02 -
yt-dlp live download & Updating m3u8 playlist
By doctorm in forum Video Streaming DownloadingReplies: 1Last Post: 17th May 2023, 10:56 -
Combing in Deinterlaced Video
By unluckyfridays in forum Video ConversionReplies: 11Last Post: 12th Jul 2022, 11:07 -
Badly deinterlaced video
By themaster1 in forum RestorationReplies: 5Last Post: 9th May 2020, 14:19
