How can I do that, is there a special plugin ?
yes, there is a logo plugin, and i can use this to display a text as a .jpg-File, but I want to display the text direct...
Is there a better plugin than DrawText (that has NO timeline function)
Thank you in advance...
You can apply the Blending option to DrawText (or any other filter) to limit the frame range in VirtualDub2. Highlight the filter, press the Blending... button...
Time Text subtitles
By vega69-ux in forum Video ConversionReplies: 20Last Post: 3rd Mar 2022, 19:50 -
Vegas set clip to specific time question
By MajorFoley in forum Newbie / General discussionsReplies: 0Last Post: 20th Dec 2021, 08:34 -
Set subtitles to start at a specific time code using Subtitle Edit
By seorimpaek in forum SubtitleReplies: 1Last Post: 28th Jul 2020, 23:03 -
MPC-BE how to display exact time of a frame?
By vhwul62 in forum Software PlayingReplies: 6Last Post: 13th Jun 2020, 02:01 -
Playing Audio at specific time with AVISynth
By smike in forum EditingReplies: 4Last Post: 5th Jun 2020, 21:39
