Hi everyone
Just bought a new tv 3 days ago, for the last 2 days it shows "horizontal colored flickering lines " mainly in the center of the screen, can anyone help me finding out if its something bad on my side before asking for a replacement/refund?
The lines appear when i switch on the tv after being off for more than 8 hours, they disappear after i switch the tv off/on 2 or 3 times and then never appear again, they appear in tv mode, media player, pc modes.
heres some videos showing the problem, the tv is a TCL 43c655
Thanks for any help
I love it when a plan comes together!
Does it occur on all inputs? What about TV settings screen?
Looks like a panel problem. You can get a second opinion by the regulars at
reddit.com/r/tvrepair -
Hi Dave.
Yes, it occurs in all inputs.
Thanks for the adviceI love it when a plan comes together! -
I would bring the tv back and get a different one.
That sounds like a bad solder joint. But one thing isn't clear to me -- did you try different source devices? Cable box, DVD player, standalone media player, etc. If it only happens with one source it's likely something wrong with that source. If it happens with multiple devices it's likely the TV.
Oh, also try a different HDMI cable. -
Hi John and Jagabo
Thanks for the advice, the problem occurs across all source inputs, ive got in touch with the shop...awaiting response, this morning nothing happened, im going to try different scenarios this weekend, different hdmi cable, powerline etcI love it when a plan comes together!
Issues with horizontal lines and flickering
By WalterR in forum Capturing and VCRReplies: 10Last Post: 27th Aug 2024, 13:56 -
4k JVC TV flickering lines
By Saitama in forum Newbie / General discussionsReplies: 19Last Post: 22nd Jan 2023, 09:18 -
What are these horizontal flickering bars?
By agisthos in forum RestorationReplies: 15Last Post: 2nd Jun 2021, 22:30 -
Flickering Green/Pink Lines?
By Okiba in forum RestorationReplies: 7Last Post: 16th Jan 2021, 01:27 -
Horizontal Lines from VHS
By Pougan in forum Capturing and VCRReplies: 11Last Post: 25th Sep 2020, 00:16
