Hello,
I don't know why, but XMedia Recode does not convert color primaries.
Here is the video, it's from youtube. I want to change the color primaries to BT.601, because it's SD VHS-Rip, not BT.709.
https://drive.google.com/file/d/1NcWKse2UxT6-v-_cuQeYeKrsO9myKooh/view?usp=sharing
After re-encoding all settings applied, but not color primaries. What's wrong?
I know, the aspect ratio is incorrect, but that doesn't matter here.
Thanks for help!
The link doesn't work, but the primaries are almost the same for rec.601 and rec.709. Converting the matrix can make a big difference, but the color primaries, not so much. The PAL and NTSC primaries are a little different, so you'd have to specify which ones to use.
https://upload.wikimedia.org/wikipedia/commons/4/40/CIExy1931_Rec_601.svg
https://upload.wikimedia.org/wikipedia/commons/e/ef/CIExy1931_Rec_709.svgAvisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
Avisynth/VapourSynth functions CropResize - FrostyBorders - CPreview (Cropping Preview)
Xmedia Recode Question
By Loryanam2 in forum Video ConversionReplies: 4Last Post: 15th Aug 2025, 21:55 -
MKV and Xmedia Recode
By Kracov in forum Video ConversionReplies: 28Last Post: 2nd Sep 2023, 05:38 -
Color Curve filter in XMedia Recode crashes app
By GoauldGod in forum Video ConversionReplies: 1Last Post: 29th Jan 2023, 18:32 -
LUT in XMedia Recode
By vh688 in forum Video ConversionReplies: 0Last Post: 8th Apr 2021, 06:38 -
Scaling using Xmedia Recode
By vinckles in forum Video ConversionReplies: 1Last Post: 9th Jun 2020, 18:26
