Hello,
Does anyone know which CDRs to use to play VCDs on the Toshiba SD3109??? I've tried a couple of different CDRs, but they dont seem to work. I however have a Star Wars IV VCD original and that works fine when I play it. So how is it that it doesn't recognize the VCD I've burned? I've read articles here which say to use CD-RW or Princo Silver/Blue CDRs?? Do these solutions really work for this player?? What's the best solution to go with before I jump into all this. Please help you. Thank you
Well, I've tried Memorex CD-RW 700 MB and though the player recognizes it and plays it, the picture is blocky, gets cut and the noise has the same problem. Should I use a different brand of Memorex??? Or should I splurge some money on the Princo CDRs??? Want to be sure what's the exact brand I should be using to get burned VCDs to work on my DVD player. I know from reading here that there's a difference between Original VCDs ( also called Pressed VCDs ) than the ones you burn with a CD writer - so that answers the question I had raised earlier.
Please can someone tell me what type/brand of CDRW to use or what type of Princo CDRs to use??
I've tried a couple of CDRs of different quality and they haven't worked - so I'm a little skeptic about the Princo CDRs
Thanks,
Which one is better? Samsung D392 (mini-DV), Toshiba P10, Toshiba H20...
By renavspainatal in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 5th Nov 2009, 09:59 -
Need DVD Player To Play DVDrs & CDrs
By DJboutit in forum DVD & Blu-ray PlayersReplies: 3Last Post: 15th Jul 2009, 16:11 -
I can Burn CDRs but not DVD on my DVD burner
By Hagen89 in forum Newbie / General discussionsReplies: 4Last Post: 10th Dec 2008, 16:47 -
Sony DVD RW DW-D18a - Won't recognise CD audio/games/CDRs
By knightime in forum DVD & Blu-ray WritersReplies: 3Last Post: 27th Jun 2008, 06:08 -
Best Buy discontunuing (Japan) Fuji CDRs!
By progrocktv in forum MediaReplies: 14Last Post: 21st May 2007, 08:51
