  1. I bought this player some time ago and it has been working fine. On the Remote Control there is a key called APPS : when I press it nothing happens.
    In the manual of the equipment I read that there is the possibility to use external apps (like VLC) when some video files cannot be read normally : I would like to know if it is possible to install VLC in the APP area of the equipment and how ii is possible to do this.
    Thank you very much
    Feb 2006
    Thank you very much
    see the manuel here - https://www.manualslib.com/manual/2863478/Mypin-4k.html#accessories
    under #6 apps i think you have to select the app folder to acces the apps, the app button on the remote may be used as a shortcut button you set.
