Ok, I have copied quite a few DVDs to DVD-R now, but every now and then I'll burn a bunch of VOBs that work perfect in PowerDVD, and once burned, will not work in my standalone player. PowerDVD is usually good for testing a DVD structure. Is there another way to verify the structure of a DVD before burning it? I hate to throw out these expensive DVD-Rs...
Expensive? I thought that you said you only paid $2.20 a piece for them!!
Your other alternative is to burn a "test" DVD on to DVD-RW media and see if this plays on the set top DVD. This is especially important if you are removing .VOBs from the original compilation so that they will fit on a DVD-R (sometimes, considerable manipulation of the .IFOs need to be done before these disks will play on a set top). -
When a CD-R costs 20 cents, a DVD-R costs over 10x's as much...THATS EXPENSIVE!!!
...and thanks for the suggestion but i dont think my dvd player will play dvd-rw's
VHS-C playback issue, playback in B&W and distorted/noisy colour.
By jpoel in forum Newbie / General discussionsReplies: 4Last Post: 11th Aug 2010, 10:36 -
DVD Backup - erroneous playback on dvd player althought perfect on the pc
By RedBolt in forum Authoring (DVD)Replies: 3Last Post: 12th Jun 2010, 00:00 -
DVD to storage drive, best media player for dvd playback- newbie questions
By omkls08 in forum Newbie / General discussionsReplies: 1Last Post: 24th Nov 2009, 11:22 -
Pinnacle 11 - playback issues on DVD - rapid playback problems
By crven in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 10:19 -
DVD+/-RDL Playback on Yamaha DVD-C750, DV-C6770, and DVD-C950
By Big C in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Aug 2007, 09:59
