Mediainfo
mp4infoCode:General Format : MPEG-4 Format profile : Base Media Codec ID : isom (iso6/mp42/vp09) File size : 13.4 GiB Duration : 2 h 36 min Overall bit rate : 12.3 Mb/s Frame rate : 59.940 FPS Encoded date : 2025-04-25 17:49:44 UTC Tagged date : 2025-04-25 17:49:44 UTC FileExtension_Invalid : braw mov mp4 m4v m4a m4b m4p m4r 3ga 3gpa 3gpp 3gp 3gpp2 3g2 k3g jpm jpx mqv ismv isma ismt f4a f4b f4v Conformance errors : 33 moof : Yes traf : Yes 0x00000000 : Yes General compliance : Element size 14384153519 is more than maximal permitted size 3592 (offset 0x272D83) / Element size 14339949926 is more than maximal permitted size 3688 (offset 0x2C9ABCC) / Element size 14144100634 is more than maximal permitted size 3688 (offset 0xE761818) / Element size 14130268316 is more than maximal permitted size 3688 (offset 0xF492896) / Element size 14116433215 is more than maximal permitted size 3688 (offset 0x101C43F3) / Element size 14104115392 is more than maximal permitted size 3688 (offset 0x10D83872) / Element size 14091823225 is more than maximal permitted size 3688 (offset 0x1193C8B9) / Element size 14079003995 is more than maximal permitted size 3688 (offset 0x125763D7) / Element size 14066296958 is more than maximal permitted size 3688 (offset 0x131948B4) / Element size 14054438102 is more than maximal permitted size 3688 (offset 0x13CE3C5C) / Element size 14042245768 is more than maximal permitted size 3688 (offset 0x148846AA) / Element size 14030517751 is more than maximal permitted size 3676 (offset 0x153B3B3B) / Element size 14017878736 is more than maximal permitted size 3688 (offset 0x15FC1662) / Element size 14004570292 is more than maximal permitted size 3676 (offset 0x16C7287E) / Element size 13992200976 is more than maximal permitted size 3688 (offset 0x1783E622) / Element size 13979671625 is more than maximal permitted size 3688 (offset 0x184314E9) / Element size 13967139915 is more than maximal permitted size 3688 (offset 0x19024CE7) / Element size 13956116863 is more than maximal permitted size 3688 (offset 0x19AA7FB3) / Element size 13944458774 is more than maximal permitted size 3688 (offset 0x1A5C631C) / Element size 13932000940 is more than maximal permitted size 3688 (offset 0x1B1A7A86) / Element size 13919610115 is more than maximal permitted size 3688 (offset 0x1BD78C2F) / Element size 13907637468 is more than maximal permitted size 3688 (offset 0x1C8E3C56) / Element size 13896231617 is more than maximal permitted size 3688 (offset 0x1D3C4671) / Element size 13884770926 is more than maximal permitted size 3688 (offset 0x1DEB26C4) / Element size 13873204299 is more than maximal permitted size 3688 (offset 0x1E9BA4E7) / Element size 13860926190 is more than maximal permitted size 3688 (offset 0x1F56FE44) / Element size 13847431594 is more than maximal permitted size 3688 (offset 0x2024E788) / Element size 13833476143 is more than maximal permitted size 3676 (offset 0x20F9D903) / Element size 13819685852 is more than maximal permitted size 3688 (offset 0x21CC4556) / Element size 13806432143 is more than maximal permitted size 3676 (offset 0x229681A3) / Element size 13794461019 is more than maximal permitted size 3688 (offset 0x234D2BD7) / Element size 13782780481 is more than maximal permitted size 3688 (offset 0x23FF66F1) General compliance : [More conformance errors...] Video ID : 2 Format : VP9 Codec ID : encv / vp09 Duration : 2 h 36 min Bit rate : 12.0 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Variable Frame rate : 59.940 (59940/1000) FPS Minimum frame rate : 58.824 FPS Maximum frame rate : 62.500 FPS Color space : YUV Chroma subsampling : 4:2:0 Bits/(Pixel*Frame) : 0.024 Stream size : 13.1 GiB (98%) Encoded date : 2025-04-25 17:49:44 UTC Tagged date : 2025-04-25 17:49:44 UTC Encryption : Encrypted Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 1 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : enca-40 / mp4a-2 Duration : 2 h 36 min Bit rate mode : Constant Bit rate : 256 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 46.875 FPS (1024 SPF) Compression mode : Lossy Stream size : 286 MiB (2%) Encoded date : 2021-10-14 07:11:13 UTC Tagged date : 2021-10-14 07:11:13 UTC Encryption : Encrypted
Code:File: major brand: isom minor version: 0 compatible brand: iso6 compatible brand: mp42 compatible brand: vp09 fast start: yes Movie: duration: 0 (movie timescale units) duration: 0 (ms) time scale: 1000 fragments: yes Found 2 Tracks Track 1: flags: 7 ENABLED IN-MOVIE IN-PREVIEW id: 1 type: Audio duration: 0 ms language: und media: sample count: 0 timescale: 48000 duration: 0 (media timescale units) duration: 0 (ms) bitrate (computed): 256.000 Kbps sample count with fragments: 439174 duration with fragments: 449714184 duration with fragments: 9369046 (ms) Sample Description 0 [ENCRYPTED] Coding: enca Scheme Type: cenc Scheme Version: 65536 Scheme URI: Coding: mp4a (MPEG-4 Audio) Codec String: mp4a.40.2 Stream Type: Audio Object Type: MPEG-4 Audio Max Bitrate: 255999 Avg Bitrate: 255999 Buffer Size: 0 MPEG-4 Audio Object Type: 2 (AAC Low Complexity) MPEG-4 Audio Decoder Config: Sampling Frequency: 48000 Channels: 2 Sample Rate: 48000 Sample Size: 16 Channels: 2 Track 2: flags: 7 ENABLED IN-MOVIE IN-PREVIEW id: 2 type: Video duration: 0 ms language: und media: sample count: 0 timescale: 1000 duration: 0 (media timescale units) duration: 0 (ms) bitrate (computed): 12014.231 Kbps sample count with fragments: 561575 duration with fragments: 9364264 duration with fragments: 9364264 (ms) display width: 3840.000000 display height: 2160.000000 Sample Description 0 [ENCRYPTED] Coding: encv Scheme Type: cenc Scheme Version: 65536 Scheme URI: Coding: vp09 (VP9) Codec String: vp09 Width: 3840 Height: 2160 Depth: 24
I try to decrypt a file with mp4decrpyt. The decrypted mp4 is successful to play.
but I get the only warning when processing decryption. My question is does it matter? I hope folks can confirm me to ignore it as I would not have another time to reprocess.
Code:WARNING: atom serialized to fewer bytes than declared size
Results 1 to 1 of 1
help understanding Mp4 moov atom
By joshua4 in forum Video Streaming DownloadingReplies: 2Last Post: 11th Feb 2025, 16:05 -
Failed to create decryptor: Incorrect AES key length (48 bytes)
By akshaysic in forum Video Streaming DownloadingReplies: 2Last Post: 14th Jan 2023, 09:05 -
Repair moov atom not found
By ncmags555 in forum Video Streaming DownloadingReplies: 1Last Post: 27th Mar 2021, 20:52 -
External HD crash and only some videos are with no preview and with 0 bytes
By Vitinho in forum Video ConversionReplies: 0Last Post: 7th Mar 2021, 00:53 -
AVCHDCoder: Cannot get "custom intro" to work (01200.M2TS is 0 bytes!)
By DSperber in forum Authoring (Blu-ray)Replies: 8Last Post: 19th Dec 2020, 07:37
