Results 1 to 21 of 21
  1. Hi, everyone.
    I have encoded mp4 (some multi-colored stripes) and MPD file. Could you advise me, which key(s) from MPD piece (below) do I need for mp4decrypt command?
    <ContentProtection schemeIdUri="urn:mpeg:dash:mp4protection:2011" value="cenc" cenc:default_KID="343fc3d2-b8f7-3636-aa80-6fd99b41e9da"></ContentProtection>
    <ContentProtection schemeIdUri="urn:uuid:9a04f079-9840-4286-ab92-e65be0885f95" value="MSPR 2.0">
                    <cenc:pssh>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</cenc:pssh>
                    <mspr:pro>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</mspr:pro>
    <ContentProtection schemeIdUri="urn:uuid:edef8ba9-79d6-4ace-a3c8-27dcd51d21ed" value="Widevine">
    <cenc:pssh>AAAANHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABQIARIQND/D0rj3NjaqgG/Zm0Hp2g==</cenc:pssh>
  2. There are no decryption keys hidden in MPD's.
    Your browser uses the PSSH (presumably from the Widevine section) from the MPD to generate a so called license request, that is sent to a (for all of us unknown) license server. The license server in turn returns an encrypted message, that holds the keys to decrypt your video.
    A browser extension like WidevineProxy2 can fetch the keys for you. Or if you are lucky a caching service has the keys, if you input the PSSH. Otherwise let us know the URL of the video (not the URL of the MPD, the URL of the video), and maybe someone can help to fetch the keys.
  3. Originally Posted by Obo View Post
    The problem is it is DRM-protected, so I can't give URL
  4. DRM protection is the whole purpose of using content encryption. If you are not willing to tell us the URL, then so be it (the forum rules allow links to free services, regardless of DRM protection).
    The best advice for you then probably is: use the browser extension WidevineProxy2 (https://forum.videohelp.com/threads/416316-%5BRelease%5D-WidevineProxy2-Extension-Bypa...s-Lic-wrapping)
  5. Originally Posted by Obo View Post
    Thank you a lot! The problem is it is not free service, it is subscription-based one.
  6. Originally Posted by Obo View Post
    actually I have one video from free service:
    https://player.eyefilm.nl/en/films/hold-back-the-sea
    can you help me with key for it?
    Dec 2021
    england
    --key ce1ae4b3267b446299f4b0b2eea7ac2a:31827947897f973133bd255a8f44171c
  8. Originally Posted by iamghost View Post
    Many thanks to you!
  9. Originally Posted by iamghost View Post
    Could you please briefly explain me how did you do it?
  10. Ambassador Of Atmosphere
    Nov 2024
    Brooklyn, NY
    I've been attempting to grab this video too, but each time I do there's no audio. Please help.
    We all bleed blue from the inside....
  11. Originally Posted by Lupine Assassin View Post
    Try the command comes from WidevineProxy2, it works for me
    N_m3u8DL-RE "https://fl-global-unified1.airflow.jetstre.am/a/0/unified/audp9-prod/kop1218485-lagelanden-en-xx-24fps-drm.ism/.mpd" -H "User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:128.0) Gecko/20100101 Firefox/128.0" -H "Accept: */*" -H "Origin: null" -H "Referer: https://player.eyefilm.nl/" -H "DNT: 1" -H "Sec-GPC: 1" --key ce1ae4b3267b446299f4b0b2eea7ac2a:31827947897f973133bd255a8f44171c --use-shaka-packager -M format=mkv
  12. Ambassador Of Atmosphere
    Nov 2024
    Brooklyn, NY
    Just tried your code, and the finished file is all pixelated. It shows the same errors I was getting before:
    02:55:25.444 WARN : Muxing to _2025-04-26_02-54-00.MUX.mkv
    02:55:25.872 WARN : [h264 @ 000001b1be32e700] top block unavailable for requested intra mode -1
    02:55:25.873 WARN : [h264 @ 000001b1be32e700] error while decoding MB 0 0, bytestream 1378
    02:55:25.961 WARN : [aac @ 000001b1c164d040] skip_data_stream_element: Input buffer exhausted before END element found
  13. Command don't work for me...need to use more steps
    Download mpd with yt-dlp
    yt-dlp --allow-u "mpd"
    Decrypt video with mp4decrypt
    mp4decrypt --key ce1ae4b3267b446299f4b0b2eea7ac2a:31827947897f973133bd255a8f44171c video.mp4 output.mp4
    Decrypt audio with Shaka
    shaka-packager --enable_raw_key_decryption --keys key_id=ce1ae4b3267b446299f4b0b2eea7ac2a:key=31827947897f973133bd255a8f44171c stream=audio,in=audio.m4a,output=output.m4a
    Merge with ffmpeg
    ffmpeg -i output.mp4 -i output.m4a -c copy new.mp4
  14. Originally Posted by cedric8528 View Post
    I don't understand why the command doesn't work for you.
    09:31:00.968 INFO : Start downloading...Vid 1920x1080 | 5923 Kbps | video_eng=5923086 | avc1.640028 | Main
    09:31:00.994 WARN : Type: cbcs
    09:31:00.995 WARN : PSSH(WV): EhDOGuSzJntEYpn0sLLup6wqGgVlemRybUjzxombBg==
    09:31:00.996 WARN : KID: ce1ae4b3267b446299f4b0b2eea7ac2a
    09:31:00.997 WARN : Reading media info...
    09:31:01.038 INFO : [0x1]: Video, h264 (avc1), 1920x1080
    09:31:43.695 INFO : Binary merging...
    09:31:45.143 WARN : Type: cbcs
    09:31:45.145 WARN : PSSH(WV): EhDOGuSzJntEYpn0sLLup6wqGgVlemRybUjzxombBg==
    09:31:45.146 WARN : KID: ce1ae4b3267b446299f4b0b2eea7ac2a
    09:31:45.258 INFO : Decrypting using SHAKA_PACKAGE...
    09:31:54.369 INFO : Start downloading...Aud audio_eng=127881 | 127 Kbps | mp4a.40.2 | en | 2CH | Main
    09:31:54.409 WARN : Type: cbcs
    09:31:54.411 WARN : PSSH(WV): EhDOGuSzJntEYpn0sLLup6wqGgVlemRybUjzxombBg==
    09:31:54.413 WARN : KID: ce1ae4b3267b446299f4b0b2eea7ac2a
    09:31:54.415 WARN : Reading media info...
    09:31:54.456 INFO : [0x1]: Audio, aac (mp4a), 127 kb/s
    09:31:59.917 INFO : Binary merging...
    09:32:00.104 WARN : Type: cbcs
    09:32:00.107 WARN : PSSH(WV): EhDOGuSzJntEYpn0sLLup6wqGgVlemRybUjzxombBg==
    09:32:00.108 WARN : KID: ce1ae4b3267b446299f4b0b2eea7ac2a
    09:32:00.110 INFO : Decrypting using SHAKA_PACKAGE...
    09:32:00.733 WARN : _2025-04-26_09-30-56.en.mp4
    09:32:00.733 WARN : _2025-04-26_09-30-56.en.m4a
    09:32:00.735 WARN : Muxing to _2025-04-26_09-30-56.MUX.mkv
    09:32:03.397 WARN : Cleaning files...
    09:32:03.501 WARN : Rename to _2025-04-26_09-30-56.mkv
    09:32:03.724 INFO : Done
    N_m3u8DL-RE.exe --v
    09:36:25.441 INFO : N_m3u8DL-RE (Beta version) 20241123
    shaka-packager.exe -> 13.01.2025
  15. Ambassador Of Atmosphere
    Nov 2024
    Brooklyn, NY
    Okay, after upgrading to the latest version of shaka-packager, your code worked. Thanks so much, IceM!
  16. Originally Posted by Lupine Assassin View Post
    Cool, thanks for your feedback
  17. Thanks IceM
    Version of Shaka also too old...
  18. Originally Posted by IceM View Post
    N_m3u8DL-RE.exe --v
    I know this thread is old but when I follow the same steps with up-to-date versions of the tools, the end result is clear audio with a broken video. Why does the audio decoding work but not the video one?
  19. Most likely because of wrong key for the video.
  20. Whichever tool I used produces the same keys. But the KID key always results in full zero. Any idea how to solve that? Or maybe can you recommend another good tool for the key extraction?
  21. Originally Posted by Allthenamestaken View Post
    url?
