I wonder if this would work for hard to find VCR gears? Will have to give this a try...
1min 9sec in
https://www.youtube.com/watch?v=eP3xJIJ-TbU
With some modifications (up to point for making form) method is fine but probably better results will be use epoxy compound and steel (fine wire) to reinforce epoxy - long term stability may be better than cyanoacrylate (generally cyanoacrylates are prone to fail in presence of humidity which is itself important for their curing but later make them more fragile and eventually cracking).
@ pandy...
You could probably count on the epoxy/steel repair outlasting the rest of the gear -
Well, using fine wire (like these in steel wool) should be OK to reinforce epoxy - alternatively some glass fibers can be used too, epoxy resin is pretty fragile. Shear strength for epoxy is better than cyanoacrylates but still not so big... Reinforcing may significantly improve this.
Depends on the size of the gears, The smaller the gear the harder to repair or remake, Anything less than a US nickel coin is a pain.
JVC HR-S6600U Plastic Drive Gear HELP NEEDED
By Mark97213 in forum Capturing and VCRReplies: 6Last Post: 13th Oct 2024, 02:05 -
help improve the radiohead's "fake plastic trees" music video
By rrats in forum RestorationReplies: 6Last Post: 22nd Jan 2023, 16:22 -
"Modern" VHS gear / Help me tackle some issues
By JoshuaLeDauphin in forum Capturing and VCRReplies: 27Last Post: 2nd Nov 2021, 14:47 -
Repair for Videos
By Libbytee123 in forum Newbie / General discussionsReplies: 6Last Post: 29th Sep 2020, 13:36 -
MP4 repair (AAC audio repair)
By holger123 in forum Newbie / General discussionsReplies: 16Last Post: 5th Jun 2020, 17:47
