  1. Hi I have got a question if anyone can help me with it
    is it possible to turn a folder of master files to a exe file
    there is a software i need but it is a folder with master files
    and it does have a exe file but it is in the sln file
    it is the full software with all the files is there a way to turn it into a exe file or a portable exe file
    or is there a way to launch the sln file
    it is a software to edit ps1 game files i have not seen any software to does it only this one.Image
    [Attachment 86567 - Click to enlarge]
    [Attachment 86568 - Click to enlarge]
    [Attachment 86569 - Click to enlarge]
  2. You need Visual studio to compile the project to an exe.
    But you also search for a binary.
    Google for Wadtool
  3. hi prowo how do i download the binary then i downloaded the zip file of the github website and it is a load of files in the folders i dont think there is a binary of this software
    https://github.com/juju2143/wadtool
    also i dont know how to turn the binary to a exe with visual studio is there a step by step guide on how to do it.
  4. I found this with a bit of searching.
    Use it at your own risk.
