Can anyone recommend a free software to use in Windows with a DVB-T USB dongle?
Results 1 to 16 of 16
Check in https://www.videohelp.com/software/sections/digitaltv-dvb-hdtv DVBViewer is the best but paid
How are you going to use the DVB-T USB Dongle?
Do you want to connect it to a laptop or a PC using a USB port?
It is better to use a DVB-T or DVB-T2 set top box as you would then get the signal out from from the HDMI connector and connect it directly to your TV or monitor (if it supports two HDMI inputs, without the need to use Windows)
On AliExpress you can find very cheap set top boxes but be warned that they can get really hot if they are too small in size -
https://sourceforge.net/projects/tvschedulerpro/
I used this years ago with a generic tuner card and it worked well. Clunky, old-school interface but very reliable and flexible. Might have improved since.
I've since moved into the Hauppauge TV-capturing ecosystem. -
What happens when you connect the DVB-T dongle to your PC?
If you get nothing then it is not supported for Windows.
Some dongles connects you to the website of the maker and from there you can download drivers and other things.
I suggest that you would give us the exact details about the model, maker, your country so that we know which TV channels broadcast in your area and if you need an external antenna to get a better signal strength. -
Actually, I asked about this a few years ago and I forgot about it, but the question remains unanswered. The DVB-T USB dongle is Technaxx Mini DVB-T Stick S6 and is recognized by Windows as IT9135 BDA Device. I use an external antenna and an internal amplifier, but I need a better software than the included BlazeDTV 6.0.
DVB viewer https://www.dvbviewer.com/en/index.php, not free (except few distributions bundled with some cards) but worth evey cents.
You can try DVB Dream with limited features. The paid version is yearly subscription which is too expensive.
https://www.dvbdream.org/
Also try ProDVB free version (Freeware)
https://www.progdvb.com/
Can I post my new themes for DVB Dream in DVB / IPTV forum?
By Dreamer in forum Newbie / General discussionsReplies: 0Last Post: 30th Jun 2024, 06:02 -
Panasonic HC-X1500 with bluetooth dongle tryout
By realspeed in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 15th May 2023, 04:59 -
Any good ATSC USB dongle receivers with TS recording?
By Videogamer555 in forum DVB / IPTVReplies: 1Last Post: 3rd Dec 2021, 15:16 -
Panasonic PV-GS120 Looking for USB driver and capture software
By mikeharakal in forum Newbie / General discussionsReplies: 1Last Post: 27th Aug 2021, 16:00 -
Cast streaming video to smart TV/dongle for more legible closed-captions?
By rawilson100 in forum Newbie / General discussionsReplies: 0Last Post: 25th Jul 2020, 14:02
